I'm relatively new to the SFF world and I've not been able to find a case to my preference so I decided to design my own. I prefer air coolers and am fairly obsessed with efficiency, so my focus is on a case that would fit the biggest air coolers with no thermal recirculation, especially between the CPU and GPU. I built a quick prototype from AL brackets and plates, which proved my concept (equivalent or better cooling compared to an open bench), and worked with a friend to put it in CAD for refinement.
Updraft MK1
Size: 275 (L) x 180 (W) x 340 (H)
Footprint: 49500 mm^2
Volume: 16.8L
Motherboard: M-ITX
CPU cooler clearance: 165mm
GPU clearance: 325mm long, 68mm thick
PSU: SFX, might fit SFX-L
Material: Steel frame, Aluminum panels, Tempered glass window
Fan mounting points:
Features:
Potential features under consideration:
GPU vents on the right direct air up and to the back. Circle is cut out for a power button and 2 USB ports are available below it. Convenient position for peripherals to connect, and no headphones jack due to proximity to motherboard IO.
Note the deflector above the NH-D15 that deflects hot air from the PSU intake. PSU drops in from the top and can be mounted horizontally in various orientations. SFX-L PSU technically can fit, but would be extremely tight for the cables. 120mm slim fan fits when using the NH-D15, considering a drop down bracket to allow a 25mm thick fan to fit. Two 40mm fans, or a 60mm fan feeds fresh air to the PSU intake, while two 80mm airflow fans provide exhaust for the chamber. The empty space in front of the PCIE slot allows space for 3.5" bays, or HDD/SSD mounts.
Bottom panel design is still not yet finalized, will have space for IO shield, and mesh/grill will cover the fans. New panel will allow for a 60mm fan to replace the two 40mm fans. Above the fans is a slot for a PSU passthrough bracket with switch.
Slots for riser and power cables will be covered by rubber/silicone grommets to prevent hot air from entering the main chamber. The slot at the bottom for the HDMI/DP cables will also be similarly sealed off. The entire front of the GPU (intake) would be sealed off from the sides/back (exhaust) so no hot air can be recirculated, forcing all the air out through the vents at the side or through the top mesh. The GPU can be adjusted forwards/backwards and up/down from the mounting points in order to assist in sealing it off. The thickness of the GPU chamber allows for two slim 120mm or 140mm fans to be mounted onto the mesh if a 2 slot GPU is used. The vents along the sides are indented inwards, forming air scoops that works well with conventional axial fan GPUs which blows hot air out sideways.
Solid back panel, the large vents at the bottom 'skids' also doubles up as carrying handles for transportation. The angled rear provides a stable platform when you rock it backwards to access the bottom IO. Still not sure if I should keep it or revert to a standard base instead.
Interestingly, two 80mm fans provides roughly the same amount of airflow as a single 120mm. Airflow focused 80mms are recommended, as pressure wouldn't be a concern for the exhaust. The relatively high velocity from the mostly unobstructed exhaust fans coupled with the lack of side intakes should result in the hot air being jetted away from the case (forming very large vortexes) so there should be almost no hot air being recirculated externally into the case (even when in the horizontal orientation).
There is still a lot more tweaking and fine detail work left to do, and I'm still undecided about a fair number of features so I'd appreciate any advice/thoughts/comments on this. In theory, it should be able to run both a 5950X and a 3090 at max load without throttling. If I can get enough interest, I will be working to bring this to market (< $200 hopefully).
Updraft MK1
Volume: 16.8L
Motherboard: M-ITX
- Intake: one 120mm fan, two 40mm fans (or one 60mm fan if not using NH-D15)
- Exhaust: two 80mm fans (main chamber), two 60mm fans (GPU top exhaust, if GPU is under 280mm)
Features:
- Two orientations, vertical for normal desk mount, horizontal (GPU facing up, IO facing in) for enclosed shelf mount (hot air blows out)
- Huge air cooling potential, open bench or better performance from the central updraft wind tunnel
- Potential for low power fanless mode in vertical orientation
- Separate sealed GPU chamber with no cross thermal flow (seals not pictured)
- GPU front intake is sealed off from the rest of the chamber, allowing air to only flow through the intake and out through the top and side vents
- Vented GPU chamber directs hot air up and to the back
- Adjustable GPU mount allows GPU to be shifted around to seal to the grill at the front
- Clean thermal flow - no dead zones or thermal recirculation for both CPU and GPU
- Tempered glass window for main chamber
- TG or solid panels are required to form the wind tunnel, mesh would reduce the effect
- Possible mesh option for a 240mm AIO
- Internal deflector to redirect CPU cooler exhaust away from PSU air intake
- Cable duct: motherboard IO and power cable are located in optimal position for a cable duct/snake to keep things neat
- Two 3.5" bays (facing out besides the TG panel) for more IO options or SSD/M2 mounts
- Alternatively up to two 3.5" HDD or three 2.5" SSD internal mounts
- 240mm AIO/radiator mount with mesh side panel
- Extra buttons in different locations (alternative location for power button, restart, reset CMOS, etc)
- Mechanical vents for GPU compartment
- Potential for temperature controlled automatic venting, only opening under heavy loads
- Filter slots for air intake points
- Leg extensions to increase GPU clearance to 350mm
- Thermal pads to sink heat from motherboard VRM/rear NVME to the exterior panel
