Understanding NUC Front Panel Header Power LED spec
BerMM
I have a NUC11TNKI5 that I'm putting in a gutted NES case. The manual says this about the Front Panel Header "[Out] Front panel LED (main color) Pull-up 300Ω to +5V". Does that mean that I need the NES Front Panel connector to measure 300Ω across the LED pins?
BerMM
Yes, apparently it does mean that. According to info from elsewhere I need to add a 300 ohm resistor in series with the positive side of the LED.
