I think you want the pattern "cut off" like on the Cerberus case, right? I agree that could maybe look slightly nicer. Could have a small effect on the structural integrity of the panel as well (could bend easier, etc). Perhaps slightly more expensive to accomplish?
For what it's worth, I think post #162 qualifies nicely as a final design, and is something I want to support.
My only concern is that having the outer shell in a big piece could cause some tolerance problem when bending it, meaning it might not be perfectly 90 degree bends, and that the screws being 2/3 down on the panel sides would apply a bit of point pressure causing the panel to bend a little. That might just be imagination. But the 1.5mm aluminium panels on my Ncase M1 were a bit prone to bending. And when they bend, it is quite permanent. Another alternative would be to have the outer shell consist of even smaller pieces. That might have already been discussed, so I will not really bring it up.
