Hi All,
Welcome to the updated version of ]M[ casing:
the casing is modular in a way that it can change its capabilities by housing not only an itx MB but also a Micro-ATX and also occupying dual full-length GPUs in an 11.8 Liter size (a first I believe):
the sizes that this case can be configured for are:
6L, 6.7L, 11.8L and 13.3L
this gives lots of options and configurations for the system. of course water-cooling is supported.
Two main colors for the casing, Black (Dark gray) and White
Black version
White version
I can't tell you all how excited I am now whilst typing this. I really hope my vision goes some where. I hope you also like it.
More details are coming with both renders and possible configs.
Please go through the comments to see the progress of this casing design.
Pricing will be released in the next two weeks. I did wanted to provide it earlier but I just need to finish the design overall.
I am planning to go on a funding campaign (kickstarter or Indiegogo)
Please give me your comments. negative or positive.
thank you.
Have a look at the earlier version below for more details on the console size (6.7L).
MicroATX Dual GPU
100mm Aircooler height support.
top to bottom: 11.8, 6, 6.7, 13.3
Black version
White version
thank you.
Hi All,
My name is Marwan,
I have been working on a casing design for ITX pc with emphasis on the gaming aspect. after countless hours and a period of about 10 months, I believe that now I can share with you my design.
The design (at least to my eyes ) is rather unique and different with lots of aesthetic and functional elements. below is the info-graphic that describes the main features of the casing:
The chassis is 4 mm thick CNC machined Aluminum that is also semi-uni-body. the doors are laser cut stainless steel. the prototype I ordered will have bushed doors. powder coating is under consideration.
Pricing is under estimation. I am currently waiting for the prototype which should arrive by early march.
Update 1: More renders added to describe the layout in-case it was not clear in the info-graphic above:
The PCIE riser will be hidden between the motherboard and the motherboard plate
As you can see there are two 60 mm fan models below, My intention is make the option of adding 4 60 mm fans, however, there might be only place for 10mm thick 60mm fans near the HDMI pass through cables.
one more render for the HDMI pass-through and the back of the PSU
The beauty of this layout is it allows the PSU to be fitted at the back of the casing so that there is no need re-route of the PSU cable.
Some would argue that the GPU layout requires ports re-routing (passing-through cables), that's true but it adds to the casing functionality by having ports close to the front of the casing for different applications such as VR.
I would really really like to hear your thoughts and your constructive feedback negative or positive.
The next update is when the prototype model arrives.
Thank you for the time you spent reading the post.
My name is Marwan,
