Stalled The ]M[ - Versatile: modular SFF casing from console size to much more
Marwan
125
125
Iraq
exactly that, this bending.
one of my early cases had some long vents and had this problem as well.
Ok got it thanks. This only happens with with doors because they are thin. The chassis itself does not suffer from this at all since it is of 4 mm thick. I will think of a pattern or shrinking the vents.
Marwan
125
125
Iraq
Are you producing this out of the US or EU?
I'm interested in testing out one of these cases.
Hello, the casing is produced out of the US and EU. Will be doing a testing batch once I finalize the design elements all together.
Daemos
108
50
I think a solution might be to have a couple small and thin reinforcement beams that run across the vent at the back of the panel for more structural rigidity. Or just split the vents into 4 sections.
Reactions: Marwan
BaK
986
973
Switzerland
Hello there, thanks a lot am glad you like it. I will provide photip of the whole assembly, maybe a short video on YouTube to make like an indie ad for the case. As for the DP cable unfortunately there's no thin ribbon cable like in HDMI. I am working on my own solution. Will see where it goes.
Cool, really interested in seeing the inside and your findings for HDMI and DP!
Reactions: Marwan
Marwan
125
125
Iraq
Thanks for the suggestions, I will do some designs of the doors and see how they look.
Sophiesff
Nov 16, 2018
I love this case, would love to see a slightly smaller variation with no hdd cage, mini GPU only and something like g unique brickless psu.
Reactions: Marwan
dragon50305
49
33
Hey I'm really excited about this case! I'm planning a build in about 3-4 months, so I was wondering if you have any rough estimates for the first batch of cases? Seriously awesome work, this is one of the best cases I've seen on the forum.
Reactions: Marwan
Daemos
108
50
After looking at the photos again, one small change you can make is having recessed screws holes so the top of the screw is flat with the panel.
The design is very clean and having non recessed screws take away from it somewhat.
Reactions: Marwan
Marwan
125
125
Iraq
Thanks a lot for your enthusiasm, hopefully in two months.
Marwan
125
125
Iraq
Thanks for the your point. it is on my mind to make the screws recessed.
dragon50305
49
33
It's been a month and I was just wondering if the timeline on the case release is still the same? I've got a bunch of idea for my next build (those zen 2 rumors!) and am trying to figure out what parts I'm gonna get.
Marwan
125
125
Iraq
it's still on timeline hopefully. I am doing some updates to the looks I hope all of you will like it.
Marwan
125
125
Iraq
Hi all I have been working on a different perforation style for the casing to give it more umm ..... look I guess ?
anyway here are some renders shots I hope you like them:
front shot:
and the last one:
So .... what do you all think??
dragon50305
49
33
I like that perforation style a lot. I think it looks better than original by quite a bit.
Edit: Also what would the liquid cooling upgrade be? Would it increase any of the dimensions or restrict component sizes?
