Very excited with this new ultra versatile case. Will there be thorough instructions to describe how to switch between the Gear One, Two, Three configurations ?
Can you post dimensions please?
Increase depth by 60mm to squeeze slim 280 rad to rear = perfect case(I know that there is PSU, mkay, 140 rad also good)
By the way, I see vertical PSU cutout on some pictures and horizontal on the others. It differs between types?
I can't wait for the case, it looks awesome ! I'm looking forward to the builds maximizing air cooling in this ! I'd also prefer blank aluminium panels, without windows. I hope that becomes an option atleast.
("last question i promise") how many PCI slots are there for an mATX board? I'm wondering if there's space to put a two-slot GPU on slot #4 ._.
I want to know if this side panel can improve compatibility of down-blowing cooler.The exterior dimensions (including feet, protrusions, etc.) are 170 x 286 x 380mm (W x D x H).
That's correct! For the final version we're anticipating that there will be either separate rear panels, or a plate which supports both PSU orientations.
Here's what a blank aluminum panel looks like, for reference!
Our prototype supports four slots currently. I believe in theory the "Core" orientation could support five, however...
Absolutely. We're looking into a lot of different ways to explain it - diagrams, documentation, videos, etc.
Whoa! Not sure if it's me but is this a space grey variant? Looks glorious btw!Here's what a blank aluminum panel looks like, for reference!
No aggroI read this review.
For my understanding, main reason for watercooling is silence and requires space for rads. Neither we can fit GTX280 in push-pull in this case for less RPM.
So this case is just big version of M1. I don't see any big improvements in cooling, just my personal opinion, don't aggro please![]()
Why this design? Were there any other sketches/prototypes?
To be blunt and honest, it feels so Junior compared to premium cases such as Dan's A4, Skyreach and the Ncase. It also looks uninspired/uninnovative, to be honest.
I guess I had way too much expectation.
Am I alone in this opinion? Anyone?
Also, is the aluminum exterior sandblasted or brushed?![]()
What I want to say is that it's much better for silence/performance to have below 800rpm push pull 30mm radiator than having above 1300rpm 60mm push radiator.
https://smallformfactor.net/forum/t...-small-meets-flexible.7475/page-5#post-100310Another question - is this going to be made by Sliger or Lian Li?
Can confirm it's not made by Sliger.
Push - pull for 30mm rad is meaningless. All 30 mm rads are already optimized for low rpm.No aggroWe just telling our opinions and it will be helpful feedback for the creators. (Maybe they will test these parameters!).
When I see pictures of the case, I'm already convinced to pay )) but it doesn't match my requirments for water-cooling. I'm so sad now.
I may have missed these:
Can’t wait.
- Can this case be flipped, so that cables come out of case on the bottom?
I second that question and add to it by asking if it could be flipped 90° to the rear so that the IO is at the back and the radiator is above the MB. would mean a larger footprint but it wouldn't be as high. For that the feet would be removable though and the underside needs to look good enough to be the new front so I don't have high hopes.
So, you want a NCASE M1 that sits on its side & supports a 280mm radiator...?
I find really interesting that someone is making case " watecooling ready" but fail at first step - thinks that 1 280 rad will be enough. And it won't even or stock speeds, let alone OC.
DA2 case have waay more flexibility
I have shift X now and slim 240 and fat 120 inside, already burned one ddc pump with temps around 70 degrees on full gaming load od slight OC'd 980ti and 6600k ( 1.280v ) . Why ?? Bcs the airflow is bad. For high end gpu and cpu you need more than 280 rad. I would glady put least possible amount of rads
And yeah ofcourse i want to OC the system when it's on the water.
This will probably be expensive case, so they have to have in mind people with watercooled vga and cpu, hard tubbing etc...
I am pretty sure DA2 will fit more rad surface but can't tell for sure untill i get my hands on one.
