Hope to support the 158mm/160mm/165mm air cooler, I need to put 7980xe or 1950x in it, but I can't use the water cooler, because I often ride in high speed rail, sometimes I need to move house, water cooling can not be safely carried.
Ordered a Cryorig H7 Quad Lumni (4 heat pipes vs standard H7) to test on my 7900X. This cooler is 145mm tall, the limit for Gear 1.
It's between the Noctua U9S and U12S, rated for 160W, so your 7980XE might work. Depending on how well it works, I might follow up with Noctua about custom cooler.
Here is a video of someone testing it on 7900X
