Hi everyone. There is new update about SR series. And now new SR mini 6th is come
There is big change with Beta version structure. And now mini use CNC craft replace old sheet metal processing.
Graphics card reversed 180° add two 80 mm fans in front of graphics card to help it reduce the temperature. In A4 case the largest wattage almost graphics card. So if squeeze more cold air toward the front of the graphics card it will decrease the overall temperature of the case.
On the other hand. CPU radiator height still 85 mm and append 120 AIO support. In picture is install corsair H60i. And use 12015 fan exhaust heat.
Compatible parameters:
3D size: 270 mm(H)*100 mm(W)*215 mm(L)= 5.85L
mother board: ITX MB
Graphic card: ITX Graphic card
Radiator height: 85 mm total
Memory height: Absolute radiator and if use AIO, pump height must<40mm and memory is 40mm too
PSU: flex 1U
HDD/SSD: 1*2.5 7 mm thick
Test result reference
Computer Configuration:
CPU: Ryzen 1700 @3800Mhz
Gpu:Geforce GTX 1070 MSI itx
MB: ASUS B350i strix
M2 SSD: Hikversion C2000 1024GB
Radiator: Corsair H60i
CPU fan: Noctua NF A12x15
SYS fan: Noctua NF-R8 *2
PSU: Seasonic SSP-300SUG
HDD: Toshiba TR200
Test items:
AIDA64 FPU & FullMark 1080p same time 20min screenshot
Result:
Noise decibel: 38-42 dB ave
CPU temperature: 62℃
GPU temperature: 67℃
MB temperature:66℃
CPU fan Rpm: 1380
SYS fan Rpm: 1800
Gpu fan Rpm: 1680
As you can see one side is intake fans and other is AIO exhaust system
Compare with cola 350 ml bottle
PSU: flex 1U
HDD: Toshiba TR200
Test items:
Result:
MB temperature:66℃
CPU fan Rpm: 1380
SYS fan Rpm: 1800
Gpu fan Rpm: 1680
