I put little pieces of flat rubber to have little bit amortization. But now after make all together have problem. PC is turning off and turning off after 5sec. Have you guys any idea what cause this problem.
I reset cmos
Change duble termal paste
Tried to lunch with one memory
Checked plug in connector of pump
My setup is:
MB: AS Rock Phantom Gaming Z390 ITX
i9 9900K 3,6 Ghz
RAM 2x32Ghz 2666Mhz 1.2 CL 16 Corssair Vegance
PSU: Corsair SF750 SFX
GPU: Evga RTX 2070 SUPER
HDD: Seagate 3,5' 2TB
SDD: Adata XPG SX8200 Pro 1TB Nvme m.2Hi
WP: NZXT Kraken X62 (280mm)
Even bios isn't turning on, does PSU Fan should be working all the time ?
video of problem below:
Redgards
I reset cmos
My setup is:
i9 9900K 3,6 Ghz
Redgards
what are your tempsI received the tempered side panel package today. It came in two pieces, a front and back panel, both of which attach magnetically. The font panel is slightly darkened with a black border. The border is ~1/2" (~13mm) on the sides and ~3/4" (~19mm) on the top and bottom. The back panel is glass and completely black. My setup exhausts in the rear so I do not have that installed. Only the exposed side of each panel is protected with a thin plastic film, but it came well packed. The panel was very easy to install.
Forgive the lighting
I would re seat everything make sure all the cables are all the way in.I put little pieces of flat rubber to have little bit amortization. But now after make all together have problem. PC is turning off and turning off after 5sec. Have you guys any idea what cause this problem.
I reset cmos
My setup is:
i9 9900K 3,6 Ghz
Redgards
Ive been eyeing that steck case let me know how you like ittell me about it, i am considering just buying a nouvolo steck and selling the streacom for whatever i can get for it.
Try removing the top and bottom filtersWell, second try with my DA2 and 9900K.
I bought another Silver Arrow ITX-R, new in perfect state because it fits perfectly in this chassis. I changed the standard fan for an EK Vardar F3-120 (1850 rpm), which I think is better.
The airflow goes from left to right, as I was advised, and I have also tested it and is a little better. And I used the fan that comes with the heatsink as exhaust on the panel, I stick it to the side panel because it gives me better results.
Old config: Aida test stress CPU-FPU-Cache-Memory 30 min: CPU 90-92º MB 46º
New config: Aida test stress CPU-FPU-Cache-Memory 30 min: CPU 80-82º MB 45º
With all this I have only improved the result with the previous config wiht the heatpipes broken in only about 10º, which seems to me little, the truth, I expected better result. It is possible that this chassis is the problem, I do not know...
Please, I would like to know your opinion.
Thank you
Here my just finished Air cooled setup for low noise and performance!!
Noctua C14s + Noctua A12x25 pulling air from outside
Noctua A15 for exhausting.
That's it! Same performance than the U9s with 2 fans, but A LOT more silent, even under load, thanks to the amazing Sterrox!
Cpu package under Prime 95, latest version, is 95 degrees, without overclock.
Super happy of the results especially the noise!
Depends from the CPU are you gonna use. If you post it, will be easier to give you adviceSorry for bothering an almost 1yo post.
Due to the lack of Ghost s1 on the market, i'm planning a build inside the DA2 as is the most beautiful but still small form factor case i know.
Would you still recommend this layout with this specific hardware nowaday? I mean, in one year maybe somebody has found a new layout of maybe there are better coolers that i don't know.
I read all of this thread's pages, plus alot more on the internet, and everyone came up with a different solution, and different results aswell.
I have not the knowledges, neither the economic possibilities of doing all of this trials and errors, so I'm searching some help here.
Depends from the CPU are you gonna use. If you post it, will be easier to give you advice![]()
It is a medium power CPU, so, in YOUR case, I suggest to get or a Noctua L12S with the A12x25 Fan ON TOP, or an amazing Noctua U9S. With bottom of them you will have a silent system.
In both case you don't need a rear fan, was pretty useless.
For sure I suggest to remove the bottom and top filter mesh, and buying this to to replace it. You can have a top slim fan to exhaust with this kit.
Than you for your answer,
My hardware will be :
- i7 9700F
- 32gb ram 3600mhz
- gtx 1660ti (planning to upgrade to a 2080 or 2080s)
- z390 aorus pro mother board
i still have to buy the cooler and power supply.
I want a deadly silent pc with acceptable temps. i Saw on the loque s1 would be feasible, but have not so many info about this case.
smallformfactor.net
- i7 9700F
- 32gb ram 3600mhz
