Interesting, I reckon this may allow use of 240mm radiator and maybe a full size pump/res. where the SFX PSU would go, but would be worth getting a few 120/240mm rads and watercooling parts and see how it may be possible to piece together a loop using these parts to see what would give the most efficient and effective loop.
On top, again mounted on two brackets. Again it fits, but barely.
Can't fit my 280mm AIO at the front. Bottom of fans hits GPU
For the rear of the case: 140mm fan fouls on front I/O and GPU, 120mm should fit in space, but don't have one test for sure. 92mm fans fit fine.
Sorry, I should have also mentioned I’ve had to mod the lower heatsink of the dark rock tf due to interference with heatsinks on the mobo and the ram. Again, will do pics when I can.Just a quick heads up to anyone considering the be quiet! Dark Rock TF for the Streacom DA2. I completed a build with this last night on the Gigabyte z390 I gaming wifi mobo. Everything fits except the dark rock interferes with the rear power connector. I’ve had to unscrew the connector and leave it hanging out the back of the case.
Will try post detailed pics of the build tonight.
Good report!So, here is my take 3 to the DA2, reinstalled the U9S horizontally but with fans as intake and a NF-A12x25 as exhaust. Everything was ready for the Kraken G12 but as I was considering in another post, the card becomes too tall even with a low profile AIO pump like the H55, the sleeve with the logo needs to be dremeled. Well, the case is ready for it and I even have the hub of an old H200i on the side of the PSU ready for the additional fansBy the way, CPU temps are amazing this way!
The two 92x15mm fans are intake on the back and exhaust on top.
Good report!
Some comments:-
a. I wonder if the rear intaking 15mm fan is supplying fresh air fast enough for the 25mm push fan of the U9S?
If not, then it might impedes the airflow rather than helping. Might try removing it to see if there is a (slight) further decrease in CPU temp?
b. How do you fix the exhaust fan to the top? Using the 2 horizontal brackets (originally on the case bottom)?
c. I gather that the NF-A12x25 is the main exhausting fan (excluding the top 92x15 fan which, IMHO, does not help much) to extract both hot air from CPU and GPU. If so, I wonder, if it is replaced by two NF-A9 fans, would this further help decreasing the CPU and GPU temp? Of course, this will be a trade-off of thermal vs acoustic.
Looking good. A NF-A12x15 fan (94.2 m3/hr, 23.9dba) provides more air with a slight increase in noise over a NF-A9x25 (78.9 m3/hr, 22.8dba).c. I actually have this being delivered by end of week:
My plan is to take the 2 middle connectors and use 2xNF-A12x15 as exhaust, but the NF-A9 could be good as well with the right fan curve.
Why do you need the fan connectors? For aesthetic? Can't the two fans be mounted onto the brackets with some siliconne mounts or some screws?
Ah...OK...for some strange reason, I thought the height is enough for you to mount 2 fans vertically, one above the other. Maybe, my mind was still stuck with using two 92mm fans (vs two 120mm fans). I wonder, if two 92mm fans can actually be installed in that fashion. Can you make a quick measurement? Thanks.I only have 2 vertical brackets, so to mount 2 o those I need the connector in the middle. Basically mounting them like if I had a 240mm radiator.
2x92mm vertical is doable but in my case the second fan (bottom) conflicts with the GPU, would have to use slim ones and therefore not worth it, but of course may work for others.Ah...OK...for some strange reason, I thought the height is enough for you to mount 2 fans vertically, one above the other. Maybe, my mind was still stuck with using two 92mm fans (vs two 120mm fans). I wonder, if two 92mm fans can actually be installed in that fashion. Can you make a quick measurement? Thanks.
More images here:
Forgot to mention this was only possible with low profile ram (2x16GB Vengeance LPX DDR4-3200), the dominator would fit but block almost half of the intake fan, not recommended.
I suspect so, I will remove the slim fans today and test again.Very nice indeed! The CPU cooler has the same layout of the ncase m1 by Ali of Optimum Tech except no rear and top slim fans. Thank you for doing this, it surely helps a lot.
No the slim fans has no significant effect/help in cooling the case?
I suspect having a hybrid card in a DA2, together with a CPU air cooler, can be quite challenging, thermally speaking.Regarding GPU cooling, the EVGA Hybrid Kit for 2080Ti is coming soon and seems to keep the card into 2 slots, could be a better choice than dremeling a Kraken G12: https://www.evga.com/products/product.aspx?pn=400-HY-1384-B1
I believe so, for now I'll keep my card stock, 79/80C during long gaming sessions is not bad, especially with max 60% fan speed.I suspect having a hybrid card in a DA2, together with a CPU air cooler, can be quite challenging, thermally speaking.
(ref: member Sirex's post #306)
Is it possible to mount the PSU directly above the motherboard on the top brackets, positioned so it does not obstruct any radiators?
I feel like using the HDPlex could allow for a lot of additional cooling options, if positioned correctly
BTW thanks heaps for trying this for us, it's really interesting seeing how you can take advantage of this chassis' versatility
There's another test I may do, Noctua D9L with fans as intake and 2x25mm exhaust (the shorter cooler would allow that), but I believe CPU temps may be worse.
In their CPU compatibility list Noctua does put U9S and D9L in the same league: https://noctua.at/en/cpu/AMD_Ryzen_7_2700X
@ bubbl3 Can you install brackets over the motherboard with the motherboard in place? I tried yesterday and failed, not sure if i'm being a n00b.
Hi all
Photos of the DA2 with the Dark Rock TF as promised.
