Stalled Spotswood Computer Cases | DA-160 Vertical Mini-ITX/DTX Case - Zero interest. Tell me why!
Spotswood
Spotswood Cases
Jul 18, 2015
68
84
spotswoodcomputercases.com
Fab'd the GPU and PSU mounting brackets.
Spotswood
Spotswood Cases
Jul 18, 2015
68
84
Refining the PSU mounting bracket continues.
The bracket was tweaked to allow removing the intrusive support beam:
40mm thick fans could be used with a 185mm long GPU:
The fabrication of the top sheet was flawless.
Finally, completed the SSD/HD mounting bracket .
Windfall
2,117
1,583
35mm thick fans could be used with a 185mm long GPU:
Be sure to round corners, nobody likes cut fingers! It looks nice!
BaK
934
934
Nice minimalist look!
No power button?
How much clearance do you have under the bottom fans?
Reactions: Windfall
Spotswood
Spotswood Cases
Jul 18, 2015
68
84
I've spent a lot of time trying to make this the ultimate case for a quiet air cooled rig.
All four sides will have solid sheeting, thus the air will be forced to flow from bottom to top (120mm fans).
GPU cables can exit from either the top or bottom.
The PSU can can be mounted vertically or horizontally.
Spotswood
Spotswood Cases
Jul 18, 2015
68
84
Everything here can be re-positioned/located (PSU, fans, motherboard, SSD, feet):
  • PSU - Can be mounted vertically, horizontally, behind/above the motherboard. Does not require a low-profile 90-degree power cord (30mm clearance).
  • Fans - The mounting plate can be adjusted vertically. Another 120mm fan can be mounted at the bottom.
  • Motherboard - The motherboard support beams (tray) can be adjusted vertically.
  • SSD - 2x SSD can be mounted on the front/back of the fan mounting plate.
  • Feet - The case can be flipped 180-degrees (GPU nose/tail up).
Spotswood
Spotswood Cases
Jul 18, 2015
68
84
I've been refining the design of the case...top with 6mm holes and an off-center 16mm power switch.
The placement of the motherboard can now be adjusted along all axis (X, Y, and Z).
Spotswood
Spotswood Cases
Jul 18, 2015
68
84
I love working with slotted extrusion. I discovered this nice airflow friendly PSU placement and all I needed to add was one additional beam.
With the addition of the sheeting, the second prototype is done.
Now just waiting on the powder coater. ?
Reactions: nick_w
