2021.4.20
The silver shell has flaws, so it was all changed to black.
Considering the high cost of the shell, I'm going to release a lighter version at 1/4 the price of the full version
2021.1.28
Final look of the case.
2020.12.18
Because the shell mold re-molded three times, delayed a long time, and now finally close to completion.
2020.6.29
I raised some money for the production of cases.
The first batch will produce 20-25 cases,and the production will be completed by August 13.
Although I don't know how to sell the cases to countries outside of China, I will continue to update the pictures of the production process and the final cases pictures here.
Here are some pictures of the final plan.
2020.5.6
NEW CNC ALUMINUM STRUCTURE
Hope you can like it ~
I gave up the plan of steel structure because of the high cost QAQ
2020.12
I have conceived this case for several months, and I want to pursue the ultimate purity, so I designed a sandwich structure to make the surface of the case without any screws, even its bottom surface.
Case specifications:
2021.1.28
2020.12.18
2020.6.29
2020.5.6
2020.12
- Dimensions (W x H x D): 171mm x 231mm x 363mm, 14.01L
- Motherboard support: Mini-ITX, Mini-DTX
- Power Supply support: SFX/SFX-L
- Graphic cards support: 2 slots with shell, 3 slots without shell, max length 335mm (without bottom 120mm fan)
- CPU cooler: max height 138mm
- Storage: 6 x SSD (sata) or 3 x 3.5" HDD
- Fans: 120mm and 90mm (bottom), 90mm (top)
