Hello,
I need support to mark cables in a joint on sata male to female cable because I want to Solder a SATA male to female joint.
This joint has burnt second time and I want to cut the plastic and solder cables directly together, so there is no more similar issue again. This power cable is powering Pcie 6+2 pin GPU, RX-580, which is used for mining and gamin both.
