Asrock Deskmini 110 need help, will this work?? low tdp gpu option
xcrco
111
84
So I'm planning to build an stx that could power a 1050/1030 based on @Harutips build
https://smallformfactor.net/forum/t...llest-gaming-pc-gtx-1050ti-g4600-sfx-mb.6247/
he is using an asus with sata onboard to power the m.2
But i'll be using an Asrock desk mini 110 , I will be using the 110w dc that supplied with it.
this what looks like, the supplied sata connector from the asrock board itself (sata combo female)
flimsy sata cable provided by asrock
As for my m.2 riser, ill be using this to supply power to the riser ( sata male 15 pin).
Will this work to grab power from the sata cable?
of course i'll be using the pentium T line in mind (35W) and probably 1030 lower tdp also 35w.
I want to use a 1050 but might be too close.
https://www.tomshardware.com/reviews/nvidia-geforce-gt-1030-2gb,5110-9.html (1030tdp)
https://www.tomshardware.com/reviews/nvidia-geforce-gtx-1050-ti,4787-6.html (1050tdp )
Can any experience minds chime on this? thanks bunch.. or is it not worth awhile
Cheers~
thewizzard1
327
246
I might suggest getting a barebones Deskmini MXM model - You can get older MXM 3.0 graphics cards for pretty cheap, and pairing that with your lower-power processor would be much easier. But also much less work for a project ;)
Reactions: xcrco
xcrco
111
84
I wish those boards are readily available but I havent seem a single page order for them. thabks for the suggestion though :)
Reldey
387
405
I don't have numbers to support this, but my gut feeling is you won't be getting enough power needed for the riser through the sata port. I might be wrong though.
xcrco
111
84
Thanks for the heads up, the desk mini was on sale a couple of days ago.. i'll just wait and hope for an am4 mobo from them then. :)
Cellbuster
I think I considered this at one point too. If I remember correctly, the special sata connector on the Asrock H110 motherboards don't provide 12v, which is all that the riser uses. Check the motherboard manual to be sure, I think there's one on asrock's website.
Reactions: xcrco
