Motherboard Smallest/Thinest motherboard with atx ability?
_ONE_
111
115
A PCIe computer???
I would rather have this SBC, thank you very much: http://www.bcmcom.com/bcm_product_ECM-CFS.html
OMG.... are you kidding me!!!
is that for real? i can't believe they put so many thing on that, but i absolutely need it to be gpu compatible.... how many performance can i get from a gpu with this msata? (over 85% would be ok)
by the way how much does that cost?
allright that's it, i'm done hidding my project, i will get back to the hexagon thread and post my build soon.
Windfall
2,117
1,584
I tried to get a quote on it, but they won't talk for any less than a guarantee you are a huge company.
Windfall
2,117
1,584
Windfall
2,117
1,584
It has mounting holes if you look carefully. HS is an option: https://www.mouser.ca/datasheet/2/618/capa500-1101612.pdf
Hmmmm...
How hard do you think connecting a gpu would be?
Using one of these: (although it doesn't look powered) EDIT: It is powered, My bad.
https://www.aliexpress.com/item/MSA...-PCI-E-Riser-x4-adapter-Card/32833715321.html
^Not that, This: https://www.aliexpress.com/item/Min...l?spm=2114.10010108.1000023.10.104c3b7a4WXWkL
Or this:
https://www.amazon.com/dp/B01FVPITN8/?tag=theminutiae-20
Or this (sorry for all the edits): https://www.ebay.com/itm/PCI-E-1X-to-Half-Full-Mini-PCI-E-Adapter-/202480463672
It should work, right?
WIth a lower power card (GT 1030, WX2100/4100) you could pack everything really tight!
775
759
@Hexagone_6 : I'm currently developping a thin-mini ITX dedicated case and the thinnest height you can achieve with a dual-slot GPU stacked over the board is 68 mm.
You add 2 x 2 mm aluminium casing and you get a 72 mm case height.
Which is not far from the S4 Mini (while being more compact).
That is INSANE power density.
@Hexagone_6
Have you guys seen @QinX's projects with Thin ITX boards?
H2O-Micro
kees KogelMier
Windfall
2,117
1,584
