Prototype Small ATX Motherbord Case!! (Updated!)
Nasp
152
121
Great looking case and I love the support for ATX as well as the standing GPU in such a small form factor. I would like to see vent holes that are a bit more aesthetically pleasing, but that's largely a subjective matter.
I haven't seen mention of drives. I see that there is a hard drive. Will it support SSDs? What's the count for 2.5" and 3.5" drives. 1 of each? 2 of each?
Also, what are your next steps? Are you looking at fine-tuning some?
OliverRH
26
83
Thanks, and yes this is just a prototype, a final design would be much more aesthetically pleasing ;)
The bottom has place for two 3.5 inch drives and one 2.5 inch. The ideal setup would be two 120mm fans for intake and then two (maybe even three) 2.5 inch SSD's!
But my focus looking forward would be the design ;)
Frazhna
29
I love the way the graphics card is being shown off. I love that it is made for SFX power supplies. I feel like so many cases want to include support for full sized ATX power supplies, and that just wastes so much space. I'm with @Biowarejak, I would like to see it oriented so that everything isn't upside-down. I also wonder if there would be room for a couple of fans below the graphics card to bring in fresh air from the bottom if the orientation was inverted.
Mortis Angelus
279
276
Great case and very appealing.
Can anyone explain to me, why all these compact cases end up being inverted? Why is being converted save space? I would love this case, but I would want it "normal" oriented.
Biowarejak
Maker of Awesome | User 1615
Mar 6, 2017
1,731
2,220
Having the PSU lower is generally preferable, but otherwise sometimes the designer just happens to have the case sit on one side of the desk or another and plans as such. :)
OliverRH
26
83
Long time no see.. I have been busy and not a whole lot has change since. But I have made some design tweeks to the front of my case, so I wanted to share that
Mortis Angelus
279
276
Personally, I prefer the slim, minimalistic/industrial look of the previous design. But hey, it is your case. :p
Btw, have you tested the airflow? With such a compact system, do you really get enough airflow? Are temps good? Some people have been complaining about poor airflow and heat issues in the Lian Li PC-O5S, and that is a larger case with "open air" design (according to Lian Li)
OliverRH
26
83
Thank you, but I just wanted something different. The temps are really good, but this is with the sidepanel off. I haven't made holes on the top and bottom, so that's why. But even tho the side panel is off, the temps are still better than my old mid case with its sids panel off. I hope to make a version 2 of the case soon, but time is short.
Reactions: owliwar and Nasp
OliverRH
26
83
Any plans to sell or are you building for yourself?
This was originally just a project build for myself because I was tired of the big and clonky atx case i had (Cooler Master 690 ii advanced). But I like the idea of selling, I just need a lot more tweeking and then I have to make a version in metal rather than wood. But feel free to write suggestions for changes :)
HeroXLazer
707
476
How are you holding the GPU in place?
JosephEK
175
84
I'm totally in the market for something like this.
Some thoughts that came into my mind looking at it:
1. Would it be possible to squeeze in half-height expansion slots beneath the GPU full-height slot?
2. How is the PSU/GPU breathing right up against the glass/acrylic?
3. (Guy above asked this), but how is the GPU resting?
4. Looks like it needs a bit of venting on the I/O side because I'd be using those 2 front slots as intake and I'm not sure where an exhaust is.
5. How do you feel about other PSU form factors? TFX, Flex ATX? May allow for some CPU air-cooling potential.
It looks great, better than most things on the market already and it's just a prototype.
SirJack
95
59
One minor thing, if you increase the height a little I think you can be flexible between having 2 hard drive mounts and or an extra 240 radiator.
If you are going to put this on sale you can add a second GPU slot behind the first for matx byilds. I think a case with 2x 240 rad, 2x water cooled GPU slots and space above the mb for custom loop all under 16L will take off.
See if that fits your vision :)
Nanook
805
793
Good idea... Unless you limit the gpu space to two single slot water-cooled GPUs, the case might go up to 20L.
