Arboreal
870
874
57
Sunny Bournemouth, UK
/snip
Handle will be our own design as well, needs a handle that looks good installed all the time.
Even better news, a handle!
I was thinking yesterday after I posted that there was no mention of a handle...
It's been asked before, and can't see the answer (please excuse andy forum blindness), what is the max height for a CPU cooler in the SM550 please?
kageiit
40
24
Any idea if this is going to be available before black friday/thanksgiving weekend? Making purchase decisions on new sff mitx build and want to get this case if possible before then.
KSliger
855
3,186
This one will be available before end of Oct, the other 5 cases I'm working on are set for before Black Friday.
When I post the update this weekend I will have a few prototypes I'd like to get rid of too.
First dibs goes to people on this forum.
kageiit
40
24
In terms of air cooling, is LP53 sufficient to tame a 9900k (which I'm planning to put in this case). Not planning on heavy oc. Maybe a modest 5ghz oc on all cores. Would be good to know what other options are there for cooling the CPU in this great case!
Since 9900k uses solder instead of goo, it should run pretty much like a delidded 8700k. Still may have to wait for proper benchmarks to be available.
KSliger
855
3,186
The LP53 should be able to handle it.
With the fans in bottom of this case you should be able to push that OC a bit too.
Problem my customer had with Dan A4 was that the NVME SSD on back of their boards would shut down the PC when too hot, and overall the whole case was too hot to touch - this was designed to fix those problems. Will have the testing completed this weekend to confirm the flow model.
Arboreal
870
874
57
That's excellent news!
@KSliger, I still can't see a CPU cooler height - what's the max please?
Prototypes sound interesting too :thumb::cool:
I have a prototype Parvum ITX which I used to go to LAN nights with.
Now looking for something smaller than my current SG13
KSliger
855
3,186
53mm is max height on CPU cooler, hopefully that covers most the good coolers. Seems a there's a big void in cooler heights till we hit ~70mm.
Also GPUs up to 2.75 slot (54.5mm) wide, up to 309mm long, and up to 157mm tall. (This covers oversized EVGA and ASUS 2080TI models)
FIVE?! o_O
I only have 4 PCs in the house...
Well.... Just don't tell the wife. =p
Reactions: talkion and TheHig
kageiit
40
24
@KSliger Are you planning on performing tests on the version with acrylic side panels as well? I feel they really elevate the look of the case without making the case too big (Like the new Raijintek Ophion), but I am a bit worried how much the thermal performance will suffer :)
KSliger
855
3,186
I am testing with solid aluminum panels, should produce a similar test result. My window panels will not be ready until late next week due to how booked our laser is right now. Updates soon!
Boganator
United States
I really REALLY like this case. Fantastic job on it, once it's available and I've swapped graphics cards (I have a hybrid now) I am buying this. I've been looking for a really small case that could handle the wider graphics cards.
