Stupid question from my side (and maybe it was already asked) : why this flat front panel?.So USB C cables arrived, but will not make it for the initial release as the leadtime from China is late into September. Rev B will have USB C.
Will have two style of vent patterns, the staggered style from earlier in thread and then this new style to go with both sides being clear acrylic windows.
Changed the vent pattern on bottom to be compatible with the brackets from Cerberus such as SSD, HDD, etc. and for mounting fans.
Bifurcation riser is go as well.
Pretty sure @KSliger runs a metal shopso is rev A going to have the acrylic panels, or just b. i am buying a case either way. you could possibly cut some slats in the acrylic for airflow
Update! Had some rework that had to be done, working on 3rd batch with all the final small fixes next week.
That explains the wood cerberus panels. I guess the SM550 will have the user's pick of the different panel materials?I run an acylic shop and a wood shop too![]()
Stupid question from my side (and maybe it was already asked) : why this flat front panel?.I find it less attractive than cerberus one..
Dang, any particular reason why?I'll make a prototype with vents, I'm curious to see how it looks
Hmmm, I'll do some last minute experiments on what will look good since I'm happy with everything except the front panel.
No wood for this case
