True. I was planning on putting good fans on the 280mm. I think that would re-widen the gap.I understand, however aio 240mm with very fans are pretty close to aio 280
Lol question is : what are good 140mm radiator fans?...True. I was planning on putting good fans on the 280mm. I think that would re-widen the gap.
The Noctua NF-A14, assuming I can set the can curve to 500 rpm. Or the reduxLol question is : what are good 140mm radiator fans?...Vardar are good performer but quite noisy..
what will be your choice? It could be nh a12-25 with 140 adaptor..
Have you seen that theres a nh a12_25 but in 140mm version on the works? They says its for 2021Lol question is : what are good 140mm radiator fans?...Vardar are good performer but quite noisy..
If you mean a 140mm version of the NF-A12x25, there already is a NF-A14x25. Did you mean a 140mm version of the high static pressure NF-F12? That would be great news!nh a12_25
To all those considering using a 645LT, be warned that you might end up with a very noisy pump. Unfortunately, that's my situation. My pump is incessantly noisy in an incredibly sharp and annoying way. I've included a video below of the noise that is haunting my life. It's not the soft humming, it's that unbearable whirring that's coming from the pump, and it's driving me crazy. Even with quite heavy headphones on, I can hear it, as it oscillates between being quiet and ramping up (no matter what curves I have it set to, it seems) - obviously I can't hear it with music going, but any pause reminds me of the noise.
I haven't tried contacting Asetek for an RMA, as I'm not sure if this is really unusual. If anyone thinks it's worth me trying, let me know, because I'm not sure what's par for the course on this type of thing.
Regardless, I am planning on immediately jumping ship to whatever Sliger comes up with for their M1 competitor. This pump noise is a total dealbreaker for me on this case, which is a real shame.
Yes, there is a NFA 14 but it´s nothing like the NFA 12. What they are going to do is release a 14 cm fan with the fan blade shape and characteristics similar with a nf a12, which for me is a trully great idea.
Noctua at Computex: gigantic passive heatsink cools i9-9900K, black coolers starting in October 2019 | PC Builder's Club
Noctua exhibited a gigantic passive cooler at Computex 2019. It cools an i9-9900K without any problems. Black coolers are starting in October.www.pcbuildersclub.com
Thanks for sharing your experience.To all those considering using a 645LT, be warned that you might end up with a very noisy pump. Unfortunately, that's my situation. My pump is incessantly noisy in an incredibly sharp and annoying way. I've included a video below of the noise that is haunting my life. It's not the soft humming, it's that unbearable whirring that's coming from the pump, and it's driving me crazy. Even with quite heavy headphones on, I can hear it, as it oscillates between being quiet and ramping up (no matter what curves I have it set to, it seems) - obviously I can't hear it with music going, but any pause reminds me of the noise.
Wait, what? I'm planning to switch my NF-A12x25 fans from push to pull on my Corsair H100i Pro in an SM570 case to give more slack to the tubes and to be able to route them around the PSU better. So that would create more noise significantly? I thought pull is better than push in terms of noise profileThat's a total bummer.
That would drive me crazy. From what I gather, the Astek pump on the 645 can not be controlled, and always spins at 100%. Luckily the pump on their rebranded Corsair and Kraken units can be controlled.
Same here. You can control how much voltage the pump receives. Here's another delightful video of me ramping mine up to 100% - you'll hear it stop a few seconds in, then start whirring like crazy. I also throttle it back down really low at the end of the video.This isn't true, I have a 645 and I can control the pump speed with my Corsair Commander Pro.
Your pump noise tone is pretty at high speed. Are you not able to find rpm that is not bother you?Same here. You can control how much voltage the pump receives. Here's another delightful video of me ramping mine up to 100% - you'll hear it stop a few seconds in, then start whirring like crazy. I also throttle it back down really low at the end of the video.
When it's throttled way down, my 3700X idles at around 65 or 70c.
No matter how I adjust my curves, the reality is that having it at a lower voltage makes the temperature creep back up, so eventually it's going to return to getting louder anyway. Even if the curve is really smooth, it's still audible whenever it changes voltages at all, on top of being consistently more noisy the higher the voltage is.Your pump noise tone is pretty at high speed. Are you not able to find rpm that is not bother you?
I'm planning to use 7v adapter on 645LT to see if it's enough to work properlly or not.
On my previous watercooling setups I always used either full push/pull or pull setup (never push alone).Wait, what? I'm planning to switch my NF-A12x25 fans from push to pull on my Corsair H100i Pro in an SM570 case to give more slack to the tubes and to be able to route them around the PSU better. So that would create more noise significantly? I thought pull is better than push in terms of noise profileThat's a total bummer.
Understood. Pump is becoming only effective while spinning at higher RPM. I will check with my setup once receivedNo matter how I adjust my curves, the reality is that having it at a lower voltage makes the temperature creep back up, so eventually it's going to return to getting louder anyway. Even if the curve is really smooth, it's still audible whenever it changes voltages at all, on top of being consistently more noisy the higher the voltage is.
In terms of noise level, to be honest I never noticed a massive change.
However in terms of performance gentle typhoon or noctua sterrox are sligthly better in pull (1-2°C)
