Thank you!@TheCrimsonRL my psu fan faces the gpu with vented panels and it gets pretty hot.
I think some new bios may be ready for some of the x570 boards. The gigabyte itx released a new bios yesterday, F4j:
- Update AGESA 1.0.0.3 ABB
- Improve Destiny 2 gaming compatibility
- Improve XMP DDR compatibility
I know a few here run it.
Hey everyone, quick question about GPU cooling. I have an asus 1080ti blower style which was attached to a kraken g12+120 aio cooler. I can no longer mount the aio in the sliger sm580. Blower style gpu coolers are the worse. Does anyone have experience with the artic accelero gpu cooler? Can anyone give a recommendation on how effective they are?
I do, will let you know tomorrow when I assemble
I've got a Founders Edition RTX 2080 with a G12 + G55 in my SM580 right now. It was a HUGE pain to get installed (you essentially put it in sideways, then finagle one tube on each side of the case spine), but I did manage it. I'll be disassembling a bittomorrow as my pslate cables just arrived so I can take some pictures for you then. That said, I did go ahead and order an Accelero III as I do not like how tight the H55 pipes are and I'm worried one of the connections will eventually bust. That, and I hate all the excessive PWM cabling and piping it creates.
@raiistar why is the leading edge of the side panel such a bright color?
Is it some sort of acrylic that lets light through?
Why would one need pslate cables? Is this like a requirement? I have the corsair sf600 platinum with sleeved cables and I'm not sure if I need these pslate cables or not.
