SirisLeOsiris
@KSliger Are you going to add the new front panel board options as orderable spare parts?
I am looking to grab a vented side panel and would love to grab the combined USB-C / USB 3 front panel board at the same time.
KSliger
Sliger Designs
May 8, 2015
855
3,186
So for the SM580, we should use the Dan a4 pslate cables?
For all SM550/60/70/80 use the A4 PSlate cables
Waiting for the Type E connector boards to come in and will make both available from parts page. =]
thoughtfix
148
212
I broke out my build log into it's own thread:
Expect the rest of the story too, as well as thermal testing and FLIR photos.
pslate
28
125
You can order from the Dan A4 listings if you are looking for unsleeved cables. For all sleeved cables the normal SM550/SM560 listings will work for all SM series cases. My SM570 is scheduled to be delivered Monday so I'll get pictures up when I receive it. I'll work to get unsleeved up under the SM series product collection as well.
Will be adding black unsleeved wire as an option within the next week (in addition to silver wire). If you'd like the black wire before then, you can leave me a note on the cart page requesting it.
raulnorry
89
143
Will be adding black unsleeved wire as an option within the next week (in addition to silver wire). If you'd like the black wire, you can leave me a note on the cart page requesting it.
Hey @pslate just curious how much business has grown in the past couple months since these Sliger cases have launched? From the look of this thread and reddit, it sounds like everyone and their brother is getting custom runs from you :D
2,682
2,807
I have one set in my Ghost and another set coming tomorrow for my Steck, like you said @pslate is becoming the go to for sff custom cables.
Nanook
805
793
I am waiting on the 24-pin cable to arrive. I just went with all black to go with the rest of the stock Corsair sleeved cables.
Cynics
@KSliger How many sm580s do you have in stock? I was thinking of waiting for a month or two to purchase.
Everyone else...Any success stories on using a 3700x on a 580 or 570? I was thinking of building a 580 with a 3700x and MSI 2080 Super Gaming X Trio. No AIO.
DrHudacris
918
1,720
Why 580 if no AIO? Why not the 560?
Reactions: thoughtfix
wsgroves
315
241
I was wondering that also @DrHudacris . The 560 seems much easier to build and hide cables in if you don't need the extra size. Unless you plan to upgrade later.
Cynics
@DrHudacris and @wsgroves , The MSI card has a pretty lengthy size measurement which I think only the 580 will fit. I chose that card because I will be doing VR and would like the extra cooling provided by MSI...
from the 1st post
SM580 (280mm AIO, 3 Slot GPU)
15.9L @ 357mm x 155mm x 287mm
  • Up to 55mm tall CPU coolers or AIO water cooler pumps
  • 1x 280mm, or 1x 240mm, or 2x 120mm AIOs in top of chassis
  • Triple slot GPU up to 330mm (even MSI Trio X and Zotac AMP cards will fit!)
  • 2x 140mm fans in bottom
BucDan
40
29
Quick question. For the sm580. Does it matter which way the psu fan faces? Towards the mobo side or the gpu side?
Not really, but apparently it affects temperatures a bit. I have mine facing the GPU, so my cabling doesn't criss-cross and the power plug has less slack.
wsgroves
315
241
@Cynics The 560 and 580 should support the same size gpu's? I have the Strix 2080 Ti and it fits no problem in the 560 and it's a 2.75 slot card.
