Log Sleeper Build: Lenovo ThinkCentre M73 SFF
hrh_ginsterbusch
672
253
wp-devil.com
Recently aquired: A fully stuffed Lenovo ThinkCentre M73 SFF. Specs are unimportant, except for the most basic ones:
- Volume: 13 - 14ish L
- Empty weight: 2.5 - 2.9 kg
- allows for mATX boards
- 4 LP PCI slots
- TFX PSU
- Production year: 2014
- Case itself is probably identical to the Inter-Tech IT-502 Desktop (expect for the branding)
Plans are: Media / storage server, going bonkers with the i7-13700k + MSI Z690 Mortar (mATX board), but maybe also "just" the Asrock Z690 PG-ITX/TB4.
PSU is gonna be either "original" TFX, Flex or HDPlex GaN (strongly leaning towards the latter). Depending on the components chosen, even a regular SFX PSU might fit.
Cooling: Liquid, either 240, 140 or the same insane ways as the Hell in a Dell, eg. with the Alphacool Eisbaer Pro ES 2U 80mm Triple (3x 80 fans, 60 mm thicc radiator). For the first two I would have to cut the side panel and modify the front cage (it basically folds forward and up), to get some proper air flow.
GPU: Either a short ITX one + riser cable (got both a GTX 1660 or an RTX 3050 ITX to pick from), or just having some fun with the Gigabyte 4060 LP.
Storage: 2x NVMe + some spinny disks for archivation / slow storage.
As somebody on reddit already tested out, the case is fitting perfectly inside a kallax shelf; I tested it for myself, and: It does that indeed - BOTH vertically AND horizontally. So this is where its gonna reside soon.
cu, w0lf.
Reactions: vinnyoflegend
hrh_ginsterbusch
672
253
wp-devil.com
While waiting for new components to arrive, I almost finished gutting the case.
Some comments along the way:
a) On-off switch: People on Thinkpad-Forum and other forums, who did the same, complained about non-standard connectors, esp. for the on/off-switch, and taking ages to find a solution. Cannot confirm that. Maybe these people used much older versions of the ThinkCentre SFF cases, or they were just too inexperienced, but the on/off-switch is just a simple combined connector, which is much more efficent and waaay less annoying to handle than the fumbly "each connection its own plug" default "ingenuity" setup.
The on/off switch combines both the power LED as well as the HDD LED on one board, and thats it
b) Card reader: Removed it, going to replace it with an USB-C socket, as the opening is nearly the right size. Just have to finely file down a bit of the front bracket / panel opening, to make it fit, and repurpose the mounting bracket of the card reader to attach the USB-C cable somewhere.
c) Cable ties / holders: What a nice and simple way to route cables, just two plastic "threads" with a knob on each end, easy to open and close, and keeps all the cable clutter tied away securely. Guess its attached to the case with double-sided tape or so.
d) CPU cooling bracket / shroud: There is a CPU cooler shroud installed right on top of the heatsink, with a simple 60ish mm fan inside. Very simple but effective. Surrounded by some foam, both for dampening and better air flow, I guess. Hot air should be exiting towards the front, where a pwm-controlled 80 mm fan sits.
e) Build quality in general: Gutting this out was a very veeery quick thing to do. Overall build quality feels really nice, a lot of things are thought out very very well.
cu, w0lf.
vinnyoflegend
63
30
- 4 LP PCI slots
- TFX PSU
cu, w0lf.
Very cool. Seems similar in size to the HP Z2 SFF but if it can take standard size and layout Matx then that is awesome.
Reactions: hrh_ginsterbusch
