Log Portable workstation: A4 H2O w/ 280 radiator
hrh_ginsterbusch
971
395
wp-devil.com
IDK if I mentioned this here yet, but I've ordered yet another PCIe 4 riser cable. One that I once saw over on r/sffpc (or could have been even on here, I dont remember anymore): Something called "server-grade" or "server-oriented", which is a very slim, "regular" cable-like looking one, that allows for much more flexibility.
Its similar to this one: https://www.amazon.com/dp/B0CGM1B9HH/
Ordered it about 2 weeks ago, parcel tracking currently says "shipped", before it was apparently at some airport sorting facility. Officially arriving between the 20th and 31st July.
AFAIK all parcels arriving from outside Europe, sent from other mail services, are automagically taken up by DHL, so as soon as it arrived in Europe, it should be trackable using regular DHL tracking service.
cu, w0lf.
Reactions: NinoPecorino
RAAM
194
88
You are getting to have quite an investment in riser cables! I hope this one does the job you need it to.
I appreciate your dedication to making this SFF build the way you want it to turn out, no matter what it takes, bravo!
Rick
Reactions: hrh_ginsterbusch
hrh_ginsterbusch
971
395
wp-devil.com
Rick
It should allow me to properly route stuff.
And for future projects, it would be such a joy to have. Been thinking about getting a HDPlex GaN 500, and downsiting to either the S400, S300 or even A4-SFX.
Also, with all the issues of the 13 / 14th intel gen currently in the news.. depending on how the Ryzen 9 9900x actually turns out, I might either go with that or a 7950X. seen several good and one great video with UV / PBO, that went as far as halfing the power consumption while retaining at least 95% of the original computation power.
Originally I planned to go for a 13900K or KS and then then wait another few years till I switch to AMD, but with the current issues, I might actually switch much earlier. Computation power is what I need, the GPU part is a nice, but neglectable thing to me :)
cu, w0lf.
RAAM
194
88
I will have some investigation to do it seems, have not seen the news on the 13th and 14th gen Intel CPUs.
I will be watching if you do downsize but do my best to not copy you as I kind of had to in my build, just liked your great ideas to much:)
Rick
hrh_ginsterbusch
971
395
wp-devil.com
It has arrived! Gonna be fun building with it .. except for the little issue that its a bit too tall 😅 - but with the armada of different riser cables and adapters, its still gonna be very very usefull, esp. with the space limitations around the mainboard area.
In a different case though? Might be the perfect option :)
Currently looking at C4-SFX and inverted NR200 / SAMA builds, on how to best arrange things :)
cu, w0lf.
hrh_ginsterbusch
971
395
wp-devil.com
So with the current Intel shitshow going on, I guess I gonna skip 14th gen altogether and do the switch to AMD much earlier than planned.
Yes, I've been pondering it for a while - but the idle power consumption held me off so far.
But then: Since buying the 13700k, I had several mysterious system crashes leading to kernel panics, which I originally attributed to some less than solid self-compiled Mixxx in combination with the RT kernel (Liquourix) I'm using because streaming / audio stuff prefers that. But then, on the other hand, I never had those issues before, even with all the RT and low-latency improvements I used so far on my AM4 systems, on older Intel and my mobile AMD systems.
Yes, I did have a lot of other isuses since i switched to Linux as primary OS in 2007, but definitely not those. Could be really just from current kernels with RT optimization, but it might also be related to the 13 / 14th gen CPU degradation issue. At least my other system with the 13500 should be safe, as those are technically 12th gen (people suggest its maybe a 12700k which didnt quite make it etc.).
At least I dont have to change the form factor AND not even the brand, as I'd be helping myself to the AM5 equivalent of the Asrock Z690 PG-ITX, the Asrock B650E PG-ITX (no USB4 / TB4, but aside of that, pretty similar (see comparison on geizhals).
cu, w0lf.
hrh_ginsterbusch
971
395
wp-devil.com
So I was pondering why one couldnt just enlarge the A4-H2O a bit, so that a 280 would actually fit on top.
Turns out, aside various minor issues like the side and front panel mounting clamps - the case is actually only 135 mm wide!
(insert various curses here)
Apparently, with the side panels, it somehow gets to be roughly 140 mm wide.
Well, so much for this.
Guess I gonna finish building with a side mounted AIO, while still not having figured out how to properly mount the GPU to the case. Maybe zipties together with the radiator / fan mounting brackets? Feels like a very janky method, but uh welll ...
.. on that note, the very next build is either gonna be a sleeper, a massive case mod with the S400 ( + 280 AIO), or going air cooled in sth like the Silverstone SG13 / SG05. Planning to switch to AM5 in September or so. Either 9 7950X, or if the 9 9900X is actually as "far ahead" as all the made-up benchmarks suggest, then with that.
cu, w0lf.
hrh_ginsterbusch
971
395
wp-devil.com
Getting increasily frustrated with the GPU situation. Considering testing and eventually switching parts with the S396 build, also including finishing the top hat.
The GPU would be perfect for a white build, and the system would profit a lot from nice cables supplied with the SF750. In its current setup, its already very portable, and weight distribution might change for the better, despite adding a larger GPU.
cu, w0lf.
hrh_ginsterbusch
971
395
wp-devil.com
I think I figured out how to get the GPU situation "fixed". Its "front side" (where the ports and PCIE bracket is located) is no issue, got a vertical mount thats now a horizontal one.
The "back" is the main issue. AND that it could still move when carried around.
My thought-up solution would be: Add a thin metal connector between where the mainboard connects in the middle of the case, and the other side of the case (front side). Either one with screw holes at regular intervals or long slots. Now add a 90° bracket with washers to this, and slot it into position, maybe also adding some cushioning material (eg. rubber) to avoid scratches to the back and bottom of the GPU.
This should ascertain that the GPU is both locked in place and cannot sag into the PSU / front section of the case at the same time.
Could even add another smaller 90° bracket to move the GPU further up or down, depending on fan noise and thermals.
cu, w0lf.
hrh_ginsterbusch
971
395
wp-devil.com
Stuff arrived over the weekend. Something called "flat jointer with long slots". 155 x 24 x 3 mm. Fits very well, despite being meant for furniture (annoyingly rounded ends etc.). Test fit using neodym 1 cm cubes hold up very well, would be even a temporary option, but needs something more solid. Either gonna be another L-bracket or just some solid standoffs / screws.
Rest should work as imagined, ie. washers on L-bracket + rubber dampenerss to avoid scratching the GPU.
Oh, and birthday present in September is deffo gonna be an R9 7950X + board.
Gonna drop it in there and see if I'm satisfied, and if not, I gonna prepare the next build :)
cu, w0lf.
RAAM
194
88
I have seen the x and x3d selling for close to the same price, is there a reason you prefer the x version or just have not found the x3d for a decent price?
My buddy got one a few months back for $549 delivered, sales tax included, brand new. I have seen open box ones from good sellers for under $500.
""flat jointer with long slots". 155 x 24 x 3 mm" also sounds like a construction item, made of galvanized steel, used to join lumber together when making trusses.
Curious to see how your mounting solution finally works out, or not, hope it does:)
Rick
hrh_ginsterbusch
971
395
wp-devil.com
In Germany, the 7950X3D costs about 70 - 80 Euro more than the regular 7950.
And I dont really need the X3D part, as my gaming is not on a competitive level (actually I havent played games on anything but the smart phone for over 7 years).
Its mostly lost in translation. English seems to be missing the correct words, so I have to work with the clunky ones.
German description would be: "Verstellbare Flachverbinder mit Langloch" (sic).
These here, specifically: https://www.amazon.de/dp/B0CF1Z4TNS
I might not have anything for the "rubber dampener" part yet, but the rest is mostly about drilling a few holes in the inner parts of the case and then combining everything :)
cu, w0lf.
hrh_ginsterbusch
971
395
wp-devil.com
Preparing for a test build for Sunday / Monday, before the final move(s). Gonna build the system in the only "true" 280 AIO-supporting case I got - well, technically, there are two: The original Meshlicious and the Meshroom S.
Depending on my mood, its gonna be either the original (cause tried and true) or the Meshroom S (because there might be less issues / improvements).
Specs for this system:
Same as before, except .. my early birthday present arrived on Friday :)
AMD Ryzen 9 7950X + Asrock B650-E PG-ITX, because of the Intel issues
Originally was pondering if I should just build in the S400 and use that for now, but as I want to do a mod with this in the next few months, this seems a bit contraproductive.
cu, w0lf.
hrh_ginsterbusch
971
395
wp-devil.com
Ugh. I'm kinda done with this (for now).
The riser routing issue remains.
It results in not being able to route the DP extension cable outside of the case because there isnt enough space left to do so. Thats because the riser cable is clashing with the case construction, even slighly bending it in shape doesnt help much. I tried several different configurations, even another few riser-ipedes, but its just not working out.
Thus I'm either going for a "classic" build, using the Thermalright Frozen Edge 240 + 2x Arctic P12 Max, or just the "FU" edition and dropping everything inside the S400 + LP air cooling.
Edit: Went for the classic build.
But: Having slight issues with the ATX power connector of the SF750. Feels like a slighty worse production than the rest of the cables.
If I'm getting power issues I first gonna try and replace it with the Fractal Design Ion SFX Gold, while ordering a replacement kit (either "regular" Type 4 from Corsair, or custom ones via CableMod). If that still somehow fails, I gonna switch to the FU mode (and Eco 105W Mode) and build in the S400 :)
cu, w0lf.
hrh_ginsterbusch
971
395
wp-devil.com
So, was thinking about rotating the GPU so the PCI panel points towards the front of the case. That would solve the routing issue of the DP extender.
Further thoughts - and tests - on this topic:
a) Mounting issue:
Tested the vertical bracket with the neodym magnets I got sitting around. Stuck the other end to one of the sides of the case. You can slightly lift it without any issues. The bracket doesnt go anywhere.
So, if we mount the GPU to the bracket, point it toward the front of the case, and attach it with two neodym magnets, it shouldnt move at all.
Next, we try a modified version of the "clamp" construction I tested out before, to keep the GPU from theoretically moving around, even if the neodym magnets somehow would come lose.
b) Fun with PCIe Riser cables: With the different position, we need a riser-pede again. But in theory, the riser thats now located to the front, behind the PSU, should have no issues clashing with the rest of the case, like it does with the riser going up in front of the MB. 30 - 35 cm regular 90° angled riser + short dual reverse might due the trick.
cu, w0lf.
hrh_ginsterbusch
971
395
wp-devil.com
Push-pull would work IF ... there werent any cables etc.
So for now I'm putting this on hold and just go directly for the FU edition = S400 build.
The 7950X in 105w Eco mode supposedly is less power-hungry than the i5-13500, so it should be totally ok to use the AXP120-x67 :)
Specs stay the same, except for the CPU cooler. Depending on size issues, might have to use a small case mod (1 - 2 mm). Going with the "tried and true" fan, ie. Silverstone Air Slimmer.
cu, w0lf.
hrh_ginsterbusch
971
395
wp-devil.com
When I was mock-fitting my 280 AIO on top of the case, to figure out how much of the side panel of the top frame I'd have to cut away to make it fit .. I thought to myself: Maybe give the 140 AIO plan a try, too. Basically the 140 AIO replaces the PSU mount bracket ..
.. so I wiggled the Raijintek Orcus 140 RBW in, and:YEEEEESS! It totally works out! Fits perfectly!
Its so nice, that I'm now strongly considering reviving this build. Would make perfect sense to put the HDPlex GaN 500 in top of the case, add a few fans, and there we go: A4-H2O, but with a twist! 😍 🥳
If I'm bored I can still go for a A4-H2O "out of spite" SE :D
cu, w0lf.
hrh_ginsterbusch
971
395
wp-devil.com
HDPlex GaN 500 fits into the radiator space like it was exclusively made for it. Might go with 2 x 80 mm + 1x 92 mm fans. Arctic has these nice Arctic S8038 that either come in a 7k or 10k rpm version. The 7k pushes up to 70 CFM, easily outperforming most regular 120 mm fans, while the 10k version competes with the T30.
Possible fan set up: Top + MB side exhaust, bottom + GPU side intake.
cu, w0lf.
