Show your new toys Topic
Skripka
Cat-Dog Perch Manager
May 18, 2020
497
614
I've been wanting to get a 3D printer for a while, but I'm only going to get one once I can make my own 3D models in Blender.
I'm planning to learn using this course which a few people I've spoken to say is a great way to learn:
I think I might start with something cheaper like that little Bambu Labs A1 Mini. I need to get this done before I start my Ghost S1 build later this year as I want to print a fan mount and some cable management clips for it.
If you're wanting to learn 3D modeling...the two go hand in hand. Although, waiting isn't a bad idea. FDM and resin printers are both advancing massively every year--the result being high-end fancy features became "cheap" and normal.
Reactions: AlexTSG
AlexTSG
641
655
www.youtube.com
TinkerCAD came up as a recommendation in a "3D printing for wood working" video I watched recently.
To be honest it looked like the 3D version of MS-Paint, but maybe I should look for a tutorial for it if it's better suited for the job.
If I have the time, I'd still like to learn Blender, but my main reason to learn some sort of 3D software was to design or tweak my own parts.
Reactions: SFFMunkee
ignsvn
By Toutatis!
1,796
1,729
The way TinkerCAD works is like playing clay / play-doh - to make a complex 3D shape, you add simple, built-in object on top of another object. Similarly, you remove shape by.. cutting it away.
FreeCAD or Fusion360 is more sophisticated, and with my current skillset, unfortunately I'm not yet able to offer any analogy.
steelfractal
Aug 15, 2019
550
674
i should get my 3dp tomorrow i starte figurering out the placement for it
this will be the surface where the 3dp will sit on i might have to cut some of the depth off 1737491093741.jpeg
AlexTSG
641
655
www.youtube.com
I hope you're putting some more support for that table though, that'll vibrate like a complete bastard
I'll second this. I have that kind of shelving system in my pantry, and it's not super stable.
Some large isolation feet under the printer might help a bit, but I'd also put additional support on the edge where you have the spirit level.
steelfractal
Aug 15, 2019
550
674
yes bought two cheap table legs that i am going to place at the left top corner and right bottom corner
and i have some sobotan pucks meant for speakers somewhere but might get something like this instead https://tapeconnection.dk/shop/91-decoupling/13048-norstone-damp-50/ as i have no clue where they are
steelfractal
Aug 15, 2019
550
674
Sorry I had to laugh LOL. But yeah I understand. Similar things happened to me with screws & heat inserts depth.
Update you know i said i had to get new rails yeah scratch that the wall mounting holes have different spacing so going to keep the ones that are already there as drilling new holes is pita i don't want to deal with
1,254
New shelf inserts instead?
ignsvn
By Toutatis!
1,796
1,729
My first failure - I've been trying certain techniques to make support materials easier to remove (it works).
But in this case, at the same time I was trying to print in 45 degree angle, and probably the amount of support is simply not enough.
Oh well, back to the drawing board.
steelfractal
Aug 15, 2019
550
674
Last was my Beyerdynamic DT-900 PRO X ... planning to get a new audio interface, a microphone and an arm next.
Have the Moto m1 myself but love the look of the
Arturia MiniFuse 1/2​
