Thanks for the comments. I'm actually eyeing for the 2700X, yes, but I'll ask her if she can stil lwait for the 3000 series. Would the 3600X be better than the 2700X though? Also, since we're going SFFC I'm reading that the 2700X is way hotter (105W TDP) than the 2700 (65W) and could be a problem even with small premium cases like Dan Case, NCase M1, etc. What's your comment on that? Take note that we live in a tropical country too (Philippines) and ambient temps here can reach around 33-35C.
I also read about the negative thermal reviews on the Evolv Shift so I'll remove that case from my choices. Although you are able to use it horizontally. Are those Dell Ultrasharps better than Mac displays?
I can't say the maximum budget but as long as the components are not overly priced then we can work something out. Anything that's bang-for-the-buck is good for me.
I can take care in choosing the storage components. I'm contemplating between getting a 500GB nVME SSD drive (preferable to save space) or a 1TB SATA SSD as storage. We have a Synology NAS at home (in a Gigabite network) so that can serve as a network storage for CAD files. Will I have any problems working off of a NAS for CAD compared to using a local SATA3 HDD? An HDD at max speed is approximately equal to the max speed a Gigabite network can offer anyway.
Also, do you have any particular case recommendations in mind? I'm having a hard time choosing a case because I'm planning on using an AIO cooler for the CPU and an open air mini graphics card. The Dan Case and NCase M1 are both nice cases but they're very expensive and very hard to get considering that I'll be buying them from the US and have them shipped here, which adds to the overall cost.
Good questions and I'll answer them to the best of my ability.
Not for rendering which usually prefers cores and threads over high clock speeds.
You make a very good point. I actually discussed this with a coworker over lunch earlier today. The way to achieve better thermal performance from either chip is to undervolt them. Here are the results for all the cores in my 2700X under an L9a-AM4 and running on a test bench:
Ambient: 27C
Stock Settings
Idle: 37C
Load: 84.8C
Avg Speed: 3.57 GHz
Undervolt by 0.08125V
Idle: 38.8C
Load: 84.8C
Avg Speed: 3.76 GHz
Undervolt by 0.09375V
Idle: 37C
Load: 84.8C
Avg Speed: 3.8GHz
Depends on her taste really. I prefer the more professional displays from other companies as they usually have matte displays which cut down on glare and reduce eyestrain.
That I do not know the exact answer to I'm afraid. I have worked on CAD files that were stored on an external USB 2.0 drive (480Mbps) and aside from the lower speed when saving or opening, I didn't have any hitches in my work.
If the NCase M1 and Dan Cases A4 are on your shortlist, why not consider the Sliger
SM550 or
SM560? This article may help in making a deciding on a case (
https://smallformfactor.net/?p=14086). Also the NCase M1 and Dan Cases A4 would most likely ship directly from Taiwan just like the NFC Skyreach 4 Mini. There are other cases such as those from Geeek, Parvum Systems, etc. but I have yet to peruse their catalogs to find ones that may be suitable here.
I hope that I was able to help in some way so far. Please feel free to ask more questions.
