already tried 1.15Vare you able to set SOC VID?
3200Gwhich CPU
AMD - UPDATE AsRock Deskmini A300: AGESAV2 Bios! Renoir kompatibel und Probleme sowie Problemlösungen (Alle Apus) Neueste Version: 3.60S | igor´sLAB Community (igorslab.de)Hey. Where can I get a modified BIOS, how does it differ from the BIOS that was removed from the asrock website (A3MSTX_3.60L)?
which bios do you use ?@D3NPA are you able to set SOC VID? It may cause the issue? Just to try out? Before setting XMP profile after a fail recovery try to push SOC VID a bit and then F10 and in next boot try to set XMP and see if it boots
Just a suggestion.Since it's a small tolerance between 2933 and 3000
Maybe it's really a bad ram batch, since I have the same, just 3200 XMP@CL18. They're tested to run with the speed said.
It may not work, but it would add XP to the memory/soc issue subject. Since it could also be a degraded IMC (integrated memory controller).
May I ask which CPU and RAM you used to run / are running?
If you prepare your desmini a300 case at the side where the hdd is you can place 2,5 Seagate 4 TB HDD. But the under site must be like a flat screen. . And you have to make the part of the case wher install the hdd flat too ..I just got my A300 build together for the first time and it's running great, I was just wondering has anyone got solutions for adding more reliable storage to it other than using another M.2 SSD? I was planning add at least 2x 4TB drives running on unRAID but it seems all the 2.5" drives out there of that size are not only too big for the Deskmini but are also SMR. Is there any way to use the SATA ports to run to something like an eSata multi drive enclosure that's powered externally? I don't want to run a full fledged NAS off the Deskmini but would like to use unRAID for it's VM capabilities and for some file stashing.
Thank you very much, first of all. This is pretty weird. Cl16 works at 3000MHz but CL18 does not? What's that?!already tried 1.15V
no luck
3200G
3.60O BIOS
don't get it wrong
cl16 works fine
cl18 not
This is observable. I mean also using Ryzen 2400G. Must be a special AsRock built-in instability feature.AMD - UPDATE AsRock Deskmini A300: AGESAV2 Bios! Renoir kompatibel und Probleme sowie Problemlösungen (Alle Apus) Neueste Version: 3.60S | igor´sLAB Community (igorslab.de)
Ryzen 4750g:
- 3.60S bios Problem : Über 2667 DDR4 hat die VEBA 8 Grafikeinheit Probleme bei manchen Ryzen Modelle. DAs 3.60R Bios Testen bei der CPU aufgrund der Güte der 4750g CPU. Die SOC muss über 1,1 V damit es stabil läuft.
It gives 4750g chips on the chip lottery they work with 1,0 SOC voltage stable. But this is the less of the 4750g that it works with. The most works with 1,1 Voltage , but it set to under 1,1 volt @ autoThank you very much, first of all. This is pretty weird. Cl16 works at 3000MHz but CL18 does not? What's that?!
Which RAM have you had before this g.skill? Just wondering. I would try out the 3.60R (works best for me) ... But if Cl16 works, it's fine then, or what do you think
@alles_alles now I know what you meant. Thanks for the link. The same behaviour you do experience, when the SoC voltage rail too weak is.
Ok, when A300 runs on power limit, it can not supply SoC voltage -> therefore the IMC degrades in terms of it's speed -> instability using higher speed -> lowering RAM CLK... what a nicework around. bravo -.- ... if the x300 has the same physical capabilities, I will be shocked.
There is tolerance in production, of course, and there is silicone-difference, but the mainboard is still facing the same problem as with 2000G Series running at high RAM CLK. SoC line Vdrops. If they remove SOC VID from BIOS options, I'm lost. It will run on 2933MHz, thought. Just remember, AsRock pushed this product with 2000G Series availability, which was spec'd at 2933MHz max. There may be just no room for silicone-tolerance from the mainboard side of things.
I bet this is not chip lottery on the 4750G - as it's probably manufacturing tolerance, which the mainboard should fiigure out / measure / be able to adjust slightly and recover from running at full speed. But what do I know.
i don't think that the chips dies. I think they are very stable . and 0,1 voltage isn't very much at this pointI think I understand you most of the time, thank you.
It's considered NOT SAFE if you go over 1.2V on SOC VID. It (may) degrades your memory controller. (Due to higher voltage the transistors get it, and are stressed more till they start fading out) Memory Controller is part of the SoC design, so the SoC voltage defines also the power for the memory controller.
I see what you are saying, but it all results into/hints at a bad SoC voltage rail / adjustment on the mainboard
Earlier it was simple: you had a memory controller in the northbridge on the mainboard.
Then Athlon 64 came along introducing built-in memory controller. Intel followed that path, also by using AMD x86-64 instruction set.
That's why it's sometimes called x86/i386 and amd64.
Now we have here System on a Chip, which means, the memory controller is not anymore responsible for CPU-RAM data only. It's responsible for the whole SoC design. And if there are additional components accessing the memory, it will go through the IMC. Hence Vega-issue is very sensetive to Voltage -- the CPU notI get it ^^
I think they had to deal with concurrency on the IMC which device has the priority to access data first, etc. This is very sensetive topic and requires logic glued into IMC by itself. IMC being part of SoC is kinda own logic inside a system. But mainboard should be able to tune it's voltage rails to accord the requirements (this is the case for up to 2933MHz on A300).
If the IMC and SoC becomes more and more insesetive to Vdrop on the other side, it would be more a development by AMD than AsRockOr the Vdrop caused by the silicone is less profound would also be AMD's achievement - maybe this is the "lottery" but I think most CPU's will run just fine with other mainboards since they have better power delivery. .. ah yea, that's what you say: there are 4750G's running with SoC on 1.0V but there most of them required SoC to be 1.1V - yea. Kommt hin
PS: Mine is running at SOC VID = 1.13750 at 3200MHz,CL18 just to keep away the Vdrop in GPU-apps. And still, it jumps between [1.033V and 1.131V in HWINFO64]
I think the chip which is responsible for the voltage-level-regulation is not the best one, i dont know, maybe @Danlopez1222 could take a look under VRM's![]()
"Default SoC voltage is 0.99v, and AMD recommends no more than 1.2v."
The main take-away here is that establishing a “safety” voltage is important, but ensuring that the voltage provision actually equates the safety input is more important. If we’ve decided that “1.3” is safe for SOC, it’s not good enough to just stop incrementing voltage once BIOS reads “1.3.” There needs to be another check.
In speaking with various contacts, we’ve heard a few conflicting (but generally converging) guidelines for safe voltages:
If you ask us, we think decent overclocks are achievable with 1.2-1.25V SOC going into the socket, and that more than that isn’t really necessary, anyway.
- Our understanding is that an AMD-made overclocking video for Ryzen (not Raven Ridge) suggested a 1.2V SOC voltage. This was at Ryzen’s launch, so is potentially outdated.
- ASUS once recommended 1.25V SOC maximally.
- Gigabyte has suggested that up to 1.3V should be OK, but spiking or maintaining spikes beyond 1.3V could be damaging to the SOC.
- Buildzoid has suggested a safety of 1.2V, which also aligns with what most early Ryzen overclocking guidelines suggested; note that this is specifically for Ryzen, not necessarily for Raven Ridge.
- Other contacts have suggested between 1.2V and 1.3V.
Ok You are rigth but at SOC Voltage. ?? The Ram Voltage does run with 1,35 Voltage, because it is an 1,35 Module. And Rawiolli goes there Often @1,4 volt or so . And VEGA is an Powerful chip , that needs power . Before you kill the SOC / Ramcontroller and VEGA you will kill your Motherboard mosfetsSorry, I welcome the fact when people try to use their knowledge to do things and stuff, but some things have to be read up.
I suggest you reading:
- How to Kill Your CPU with “Safe” Voltages | Raven Ridge SOC Voltage Guidelines.
- AMD CPUs AMD Ryzen (2000-Series) Overclocking Guide
Also very interestng video. Check beginning till ~3:00mins. (For Raven Ridge)
I'm not arguing with you, I'm just pointing out, that there was made an observation by couple of people and companies.
It's wide known in the community, go over 1.2V to o/c and test, but not on 24/7 system.
In the end, I am not trying to advice you to do something or not, for me it does not matter. I just wanted to shed a bit of light on this SoC VID topic.
Don't forget, when you speak about USB running at 5V - 0.1V is not much, that's right.
When the relative voltage is as small as 1.0V than 0.1V is like 10% more. That's rather "much" to me
PS.: Our AsRock mainboard has no LLC-Settings, which are actually used to prevent Vdrop.
Edit x: From Nexus Article Conclusions:
Yes, I can imagine that one on A300Before you kill the SOC / Ramcontroller and VEGA you will kill your Motherboard mosfets![]()
After reviewing the video by myself, I have to admit, it's rather safe, but we do not know which Voltage is truly on the PINs.Soo 1,237 voltage should be ok at deskmini and the 2000 apu.
This is also my understanding, Renoir's 7nm process will also help in terms of voltage. This has to be tested out, I agree.I don't think you need 1,2 Voltage at Renoir. Maybe 1,15 or so .
F4-2400C16D-8GRS at 2933 17(16+gear down)-18-18 probablyWhich RAM have you had before this g.skill?
Yes I found the posts for the extra USB ports, I already have one installed actually, but not the audio cable. Did a search for 'audio' in the two A300 topics as well but found nothing. I could have sworn I had found a listing on aliexpress once for a cable that looked exactly the same but last time I searched there the results didn't give anything useful. My current speakers are connected with usb so no direct problem but perhaps for the future I would want to use it.
got that cheap ram
cl18 profile doesn't even boot, lol
even with 1.35V
Not your normal A300 build. Damn Josh builds cool stuff.
He didn't. He tried it and it didn't work so he switched to a 2400g.i could not find any information regarding the bios version he uses for this build. 3700x in deskmini, how did he manage to run it in a300?
