Fitting a B550 chipset on there would be a real challenge considering the A300 doesn't actually use a chipset and is still densely packed.IDK - if ASRock took the new B550 chipset, gave it a quality VRM, NVMe Gen 4, 10 Gig eithernet, allowed overclocking, and kept everything else about the A300 the same I'd probably buy it.
The A300 designation means just a "virtual", nonexistent chipset. The APUs don't actually need a chipset for basic functions, and even these are not fully available on Asrock board (like all USB ports supported by the APU itself). There are differences between APUs. The Athlons offer one M.2 NVMe 4xGen3 and one 2xGen3, while the higher APUs offer two 4xGen3 lanes.It uses the AMD A300 chipset.
As mentioned above, A300 is not an actual physical chipset but rather a set of system conditions (including firmware/BIOS I would assume) for the SoC (which all Ryzen chips are) to operate by itself. The CPU/APU has all it needs in terms of SATA, PCIe, USB etc., the chipset just adds more. The same goes for X300, though I would assume that includes stricter design requirements for VRMs and board quality as that configuration supports overclocking and SLI/CF.It uses the AMD A300 chipset.
ASRock DeskMini A300 Series
AMD AM4 Socket CPU, - Picasso, Raven Ridge, Bristol Ridge, up to 65W, - Support MAX Height ≦ 46mm CPU Cooler<br />High-Speed DDR4 Memory, - DDR4-2933MHz (Ryzen), - DDR4-2400MHz (A-series)<br />Dual Ultra M.2 (NVMe), - M2_1 M.2 (2280) – PCIe Gen3 x4, - M2_2 M.2 (2280) – PCIe Gen3 x2/x4<br />2 x...www.asrock.com
Guess I missed the part about processor-direct access. I'll go back in the corner.
"To satisfy customers who value the smallest form factors, AMD’s X300, A300, and PRO 500 chipsets provide processor-direct access for excellent performance. The enthusiast-oriented X300 chipset is perfect for enthusiasts and overclockers, while the A300 and PRO 500 chipsets are geared toward practical consumer and commercial users who need a simple, small solution."
It is quite irritating: AMD talks about the X300, A300 and PRO 500 as chipsets, but they have no specs listed in the table. Maybe these "chipsets" mean simply different board component parameters and quality levels. The Asrock A300 is most certainly no PRO quality level board.Guess I missed the part about processor-direct access. I'll go back in the corner.
Hello.
I have a small problem with my Deskmini A300. Sometimes, only when I cold start it, it doesn't post. The fan is working, the blue light is on, but the monitor remains in stand by. To start the computer I have to shut it down by pressing the power button and start it again. Usually the second time starts.
Tried about everything reset CMOS, flash again the BIOS, use another power brick, check ram.
Do you have any idea what may be causing the problem?
Thanks.
define aftermarket?Anyone running aftermarket CPU coolers?
can anyone identify these headers I've pointed out in the pics?
is the white one near the USB header just a differently formatted USB header?
what are the other ones? especially the itty bitty one.
