Meaning, can I use three discs at the same time? Or is there some limit
Yes, that's what I did (1 M2 + 2 SATA).
RAID 0/1 is supported but I can't tell if it's with the SATA drives, the M2 drives or all of them.
Do you need all the details, or just the mounting holes?does anyone have a 3d model or stl, obj, of the asrock a300 motherboard?
that would be great if you have both if you only have the io cut out that's fineDo you need all the details, or just the mounting holes?
There's a file in the resources section for the mounting holes + rear io cutout.
thx.STEP - STX Motherboard Blank
Since the release of the deskmini a300, I guess I'll stop hoarding my model of an STX board. Based of of a STX CAD file from Sapphire, and James's STX tray. Have 3D printed a case using this model and I can confirm it is accurate. Made a new...smallformfactor.net
Actually, the Raspberry Pi 4 is feeble unless you are only emulating N64 hardware and earlier. RP4 is insufficient for Dreamcast emulation or later, or serious 3D arcade games starting in circa 1998. Plus try any fancy-shmancy 3D effects on your arcade front-end and watch the whole thing choke and stutter insufferably, dead in the water. Even a ~$100 J3455-based NUC is far superior to it. My goal is to load up a 4700G build with LaunchBox and go to town with that which should be sufficient up through Wii U emulation.For an arcade cabinet you're probably better off with a Rasberry Pi 4.
Due to everything under table, I can't command about new AMD processors condition.
But I have a good news that we will have new DeskMini product very soon.![]()
There is zero reason for them not to be compatibly :/Dang, I was hoping the a300 would retain compatibility with 7nm APU's as long as they were AM4. If they are releasing a new model I am guessing that means they aren't compatible.
I was also reminded of this today. Add this to the growing list of reasons "for" that the old A320 chipset is going to be used in ASRock's upcoming Jupiter A320.There is zero reason for them not to be compatibly :/
At least with the next gen APU since APUs lag a generation... I was hoping to get another year of upgrades on the a300 as well.
Made a quick mod for fun to see if it would make a difference.
Changed the fan on the Noctua cooler to the Noctua NF-A9 PWM 92x92x25 from the slim version.
Amazon.com: Noctua NF-A9 PWM, Premium Quiet Fan, 4-Pin (92mm, Brown): Computers & Accessories
Buy Noctua NF-A9 PWM, Premium Quiet Fan, 4-Pin (92mm, Brown): Case Fans - Amazon.com ✓ FREE DELIVERY possible on eligible purchasesamzn.to
I then added some scotch tape to the holes from the fan intake not being used to pull in air to try and force more air out the side.
Works great. Looks awful. Ignore the residue of dust on the machine![]()
minor update
- about fan > heatsink mounting: as mentioned above stock screws used for nf-a9x14 hs-pwm fan on nh-l9a-am4 cooler are too long here for the required bottom fix (see left pic), so i got few mm shorter screws and applied double rubber spacers between screw head / mounting hole. this is a much more secured and cleaner solution (except for the diy painting of copper screws to black).
- about putting back the 2 screws in place which fix the case lid to the side panels: it was much easier than expected, a very small & thin flat screwdriver did the job in 3-5 minutes (tiny screws to small holes -> using a magnet & gravity wisely can help a lot).
so finally my a300 build with the new super silent 25 mm tall chromax fan is ready (8-900 rpm in idle @ silent settings), no more loose screws and duct tape fixing. will serve well for the coming ~6-8 months till renoir arrives (if ever happens to deskmini) and i'll have to take it apart again![]()
I certainly wouldn't be surprised if ES or QS silicon of these has been in circulation for 6 months or more. Given that the mobile APUs launched at CES, they must then have been in mass production for at least a couple of months, and after all desktop APUs are the same silicon binned a bit differently, stuck on an AM4 substrate and with an IHS on top. So a 2019 stamp on the IHS of an ES or QS sample doesn't surprise me at least.2019?
nice, see my chromax version of this mod, black looks way better:
me personally waiting for something like ryzen 7 4700g since i've finished this mod (see below - sorry for separate post, my mistake).
fingers crossed for all renoir apu support!
How did you seal off the unused air intake holes to help force air across the other components? That is a cosmetic thing I'd like to tackle.
Edit: I see this was posted a few times by you in 2020 now. Thank you for the idea, it worked great. My plan to take duct work and make a shrowd for the original slim fan would have been a lot harder.
