Damn are you saying I won't be running faster with those sports shoes I just bought ? I feel scammed
haha
Yea about the graphene coating there won't be much difference, the base itself is still copper so the CPU > Radiator thermal transfert will be the same. Then maybe, a big maybe, somehow the thermal transfert between copper > graphene > air is a bit better than copper > air. But even that might not be a big difference.
It does indeed look a lot better though, like the noctua chromax stuff.
Fun fact - you know what Cryorig still can't do properly with C7G? You can't mount the cooler on AM4 with just included wrench/screwdriver because you need to move the standoff/distance screws and the included wrench/screwdriver can't be used for those. You need a flat 8 mm wrench for that regardless of the fact that included wrench/screwdriver thing is 8 mm as well.
Replaced the fan with noctua one. On low RPMs the noise tone is better and is somewhat tolerable. On full load it still whines though.
Oh yea I remember that ! And i had to move the legs of the heatsink and it was a mess too ! And also I had to cut the backplate because the Intel holes part was dangerously close of some component at the back of the motherboard, the Cryorig experience haha
