I'm very interested in the Sentry 2.0, but I don't like the "back pad" which you put on the case to "eliminate dead air" behind the GPU and support it in the horizontal orientation.
My plan is to use a short GPU and an AIO water cooler for the CPU. The "back pad" restricts the height of the AIO radiator/fan. I would also drill some new ventilation holes so the AIO fan/radiator had proper ventilation on both sides. The "back pad" makes this impossible. Is there any chance the "back pad" is removable so I can accomplish my goals?
Maybe you can shorten the "back pad" and pre-punch AIO radiator fan vent holes -- that would be fantastic!!!!
Thanks -- Bob
Thanks -- Bob
