planning on using the z270i from asus which uses the same 8pin for power. but i only have the pico psu. would it be ok to use the 4pin only for daily use? im not planning on serious overclocking.
Will a 25mm thick fan fit if you take the stock noctua fan off and are the temps better that way instead of the normal way
[/URL][/IMG]![]()
i cant see and bracket. planning on using this setup also.
I almost bought bunch of parts before but luckily I didn't give in. There were a lot of changes, in terms of the parts I want to use, that would have made my initial purchases a waste. I suggest buy the parts that don't change significantly in short period of time (e.g. power supply, cpu cooler).
Have you seen the STX160.0? It's got a face only a mother could love, while the S4 Mini is a work of art.
A S4 Nano* with that board would look amazing.
*Though I would humbly suggest picking a different naming scheme to make it easier to find your case without sorting out tons of Samsung stuff.
Agreed. The housing on that thing is gross. Not sure why companies love shiny black plastic so much.
the 4 pin connector should be sufficient - I've run 125w Phenoms off a 4 pin plug!
[/URL][/IMG]![]()
Dude I'm just as hyped as you but I understand that Josh is working his butt off so I'm just waiting for his emails patiently since I know my motherboard and possible GPU arent even released yet. (lol)Hey, just wanted to ask a question... I'm not asking to try and bump Josh, as I know he's doing all he can, just wondering what you guys been doing with your components while waiting for your S4 Minis? This is all assuming you have one paid for and are waiting, as I am. My mistake, I guess, was ordering all of the parts and unrealistically having an "Amazon-like" mindset when it came to the S4 Mini.
Anyone else out there as impatient as I am? I have all parts
I have been trying out as many fan configs as possible, looking for the best combo of temps and noise levels. I bought a Scythe Slipstream 120mm x 12mm, but wasn't happy with the acoustics and lack of PWM support. So I picked up two Rosewill "Ultra Slim" 120mm x 15mm fans to test out.
I found that they fit comfortably under my Zotac 1050 Ti with the shroud/fan removed. I'm using Speed Fan to set a nice fan curve based on GPU temp. I'm seeing idle temps at 30-31C (1000RPM), and max load temps around 64C (1500RPM).
Initially the fans didn't fit in the bracket over the motherboard/CPU due to the height of my EVGA RAM. I then upgraded to shorter Corsair LPX series RAM which gives you just enough space for proper fitment.
To my ears these fans are quieter and also seem to move more air at lower RPM than the Scythe Slipstream. They are PWM fans, and have a black sleeved cable. The cable is actually long enough to snake from the GPU bay to your fan headers without an extension. So just another option to consider depending on your build.
I purchased a case of the Scythe fans a while back so I've not actually purchased other slim fans to test--so I would definitely recommend experimenting with them.
I purchase two Scythe SY1212SL12H-P 120mm slim fan and they work great and quite! They are 2000 rpm and have pwm control as well.
Jay, dude you saved me! I was ABOUT to buy 2x 2000RPM slipstreams for my S4 mini today on Amazon. I saw these Rosewill fans on Amazon and I'll be buying 2 of these instead.Thank you for the comprehensive review!
That is the exact model I bought from Amazon. It is not a PWM fan, at least mine isn't. Does yours have a 4-pin connector?
I have tried a few models, but the Rosewill was the only fan outside of the Scythe that I like so far. I think we are all just waiting for the Noctua 120mm x 12mm to FINALLY be released.
Ha, they are both good fans I don't want to steer anyone in the wrong direction. The Scythe model offers greater component flexibility. You could try one of each and see which you like more.
Have you tried the prolimatech ultra sleek vortex 12?That is the exact model I bought from Amazon. It is not a PWM fan, at least mine isn't. Does yours have a 4-pin connector?
Yes! Please release it Noctua!
If it's not released by Computex, I will go to your booth and force you to sell me one of the prototypes![]()
