S4 MINI Classic (S4M-C)
SkudShark
77
86
:thinking emote:
Depends, do you want it to turn homicidal ?
mtl171
60
57
Just ordered 2 NFA12x15 PWM fans to swap out my GPU fan (some rosewill 120mm) and to add a extra case fan behind the GPU!
Has anyone with a revision 2 mini mounted a fan behind the GPU without drilling a extra hole in the frame? Thinking about using some double sided type but not sure if it is enough.
DocH
G4G
Apr 2, 2017
314
306
Hey Josh I am assuming your going to upload samples of those new skins? I see four we haven't had a peak at well maybe the zibra at the end of your video.
Edit: also it would be nice to know which skin corresponds to which look. Kinda hard to tell from your store with how it is posted.
Reactions: mtl171
DocH
G4G
Apr 2, 2017
314
306
Such an awesome case and it gets better with every version. If I didn't already have more cases than PCs and more PCs than uses, I'd snap buy one right now.
This is literally becoming me. I have two pcs. My second S4 mini comes in shortly. I also have the caylos nsg coming into a couple months as well. To many good choices.
Josh | NFC
Not From Concentrate
NFC Systems
Jun 12, 2015
1,869
4,468
www.nfc-systems.com
I'm working on this. In the meantime I have it up for the custom skins. Sorry for the trouble
DocH
G4G
Apr 2, 2017
314
306
oh no worries josh i know your a busy man for R3 just wanted to make the suggestion as i can see a lot of questions coming your way cause of it. Keep up the good work man
Geran Brown
52
25
I'm so mad I missed the most recent pre order. The only thing that was holding me back was the need to lay it horizontal and now with those little feet I could. Maybe I'll get in on the next one depending on the availability of other cases.
Reactions: royalba94
royalba94
AVAENTUM SLEEVING
Apr 2, 2017
268
434
Avaentum.com
Yeah, I missed it too but more because I hadn't quite saved up the money yet lol
All the new Bezel and custom wrap options got me wishing I'd borrowed the difference cause they look so darn good!
Next time...
