they are set to exhaust, so it's a pull configuration. I've read a few times that this is supposedly better than using push in the Meshlicious, so I wanted to give it a try. Truly, temps haven't changed much, but I guess that only works because of the 22 mm radiator.What's the direction of the front radiator fans (the white ones)? Are they sucking air in, or blowing out?
The other issue was, that I couldn't find the original small screws for the radiator, so that solved the issue quickly, too. And I didn't want to wait that long with finishing the rebuild, as I'd have to order new ones.
cu, w0lf.
