I need to find a 24 pin right angle connector but need it the opposite way to the conventional 24 pin right angles you find. I've tried looking but unsure where or what to search in order to find what I'm looking for and thought someone on here might be able to help me out.
I need one of these but instead of going away from the board it needs to go inwards towards the board if that makes sense? Basically my sff PC motherboard 24pin sits right at the bottom of the case so a standard way just isn't possible, I need to go into the motherboard so on my board it faces up towards the CPU cooler. Does anyone have any links or search terms I could use to find this? I'm sure someone must be selling these?
Huge thanks!
Huge thanks!
