lowest profile cpu block with right angle fittings for am4
Elerek
228
165
Having some trouble finding the heights for cpu blocks and fittings.
Best I can tell:
keep out zone under a motherboard is 4.1mm
motherboard thicknss is ~1.57mm
am4 socket height 7.35mm (source https://hardforum.com/threads/am4-socket-dimensions-help-needed.1930302/)
I'm trying to make a custom case with an interior height of 50mm, so that only leaves ~36mm or clearance for a cpu block and some right angle fittings.
Anyone know of a set that would fit?
GentlemanShark
Asus RMA sucks
Dec 22, 2016
358
148
This guy is a really low profile water-block and supports AM3, so depending on your mobo, it may be compatible. Similarly, you could make a bracket if it doesn't work.
