Realan i3s passive cooling mod
Spartoz
Hi
I always wanted some cheap tiny PC that would make no sound at all while using it
So recently i bought some parts for cheap
That's what inside the PC today
- i3 3225 (55W TDP) with intel HD4000
- Prolimatech Megahalems cooler
- 8Gb DDR3
- Asrock H77M ITX
- KingSpec P3 120Gb SSD
- Chieftec 120W ITX power supply
- Realan i3s case
An now for the build Log
The case
Looking for how much place I have for the psu
Screws diddn't match so hot glue it is
Inside done
Test fitting before cutting the metal panel
The final product
I'm happy with the result and the temperatures are good too, after 15-20 minutes OCCT + Furmark / Aida 64 CPU+GPU torture test, im getting max 67°C on the cpu
Reactions: Soul_Est and Nanook
smitty2k1
978
500
Well when I started clicking through pictures I started asking myself "how is he going to passively cool this?" Then I came across the photo of the tower sticking out of the case.. not the direction I thought it would go! But it looks really cool, kinda like an old tube amp!
Realan makes a really great case, I've got a i3 3245 in mine with that ASRock board.
Realan makes DC-ATX power supply boards that should fit in the mounting holes provided in the case if you ever have issues with the one you purchased. They are pretty cheap and widely available.
2,201
2,225
That's an interesting build. I have to ask: could you retry the torture test with the case stood on its side, to see how much (if any) difference the easier airflow path through the cooler would make?
Also: why no I/O shield?
Spartoz
Yes I am going to do a torture test again and will post the results but not imediately, it's more than 15°c hotter inside my room now than 20 days ago, :confused: I will wait until the heat wave stops
And for the I/O shield, I dont have it, I bought the CPU, mobo and cooler secondhand and it diddn't came with it
Spartoz
So, little update
I did an hour test with OCCT
Still really good temps :)
After 40 minutes they stabilized and stopped rising
Then I tested with the case vertically and I lost about 5°c, not a lot but still noticeable :)
2,201
2,225
So, little update
73 degrees max with passive cooling is nothing to scoff at! You've even got headroom for a (slightly) faster CPU should you want/need it :)
