Geran Brown
52
25
Hi @LukeD, I am really excited about this case and have been holding off building my wife's and I new computers since we want small mATX setups and yours fit the bill.
Can't wait for it to be released.
Reactions: LukeD
LukeD
529
1,337
Sydney, Australia
Playing around with the 1080 Ti's .... (aka ... the FSP octopus attacks !!!!) :)
some interesting facts ...
Flex SLI bridges as still as good if not better than HB :p
7700k overclocking is not all its hyped up to be (i guess it depends on the resolution) :p
LukeD
529
1,337
Sydney, Australia
Yep, pretty sure its just down to deviation .... And no, those aren't averages ..those are single runs. But i did run the HB ones first ... so in theory the Flex SLI bridge results should be lower ? cards should be hotter ?
Or do they need to warm up before they start posting some serious numbers ? ;)
iFreilicht
FlexATX Authority
Feb 28, 2015
3,243
2,361
Germany
freilite.com
Eh, my guess would be that if you didn't restart your PC before running the HB tests, your machine might've had tasks running in the background already that slightly reduced performance. Then, when you restarted to install the flex bridges, all resources were a clean slate, so the benchmark had less problems with memory fragmentation and the likes.
LukeD
529
1,337
Sydney, Australia
Both fresh restarts before the tests were run. (As I had to turn the system off to install the HB bridge)
Both times the system was not connected to the net.
But now you have me intrigued :p
I have no choice but run one of those tests 5 times with each bridge, see if the deviation changes much.
Reactions: iFreilicht
LukeD
529
1,337
Sydney, Australia
Hmmmm....... the only theory i have about this is that the flex sli bridges don't hold the cards as closely together as the HB bridge... perhaps one of the cards is getting more air with the flex bridge ?
RobonHood
So Hold on a second, you're not doing X99 now? What about the Ryzen photo bomb lol. I assume it's just the testing of multiple hardware specs in your cases for the rest of us to find out what would work best for us...right ;)?
Reactions: LukeD
iFreilicht
FlexATX Authority
Feb 28, 2015
3,243
2,361
Germany
freilite.com
Weird and interesting results.
Hm, that might be the case, but it seems to me like the mounting points on the case provide much more rigidity to the cards than the SLI bridge. Especially considering that the card ege connectors on the bridge have a little bit of slack to them as well. It might be that the traces on the Flex SLI bridge are of higher quality in some way, but that's not something I can make an informed statement about.
Reactions: LukeD
LukeD
529
1,337
Sydney, Australia
No. I'm not going with X99 for my own build. I just sold my 6800k and EVGA Micro 2. I loved the motherboard but there was absolutely no gaming performance benefit of it over the 7700k. Also the additional 50 Watts of power required for the 6800k would be pushing the setup of it with 2 x 1080Ti SLI's to the limit.
Also there was better support for other components, like the RGB ram on the Z270 platform than on X99. Ironically enough on this motherboard it doesn't work 100% hahaha.
Yeah, the point of me testing various hardware combinations is to see / show people what combinations work and how far it can be pushed.
X99 + 2 x 1080 was a really good sweet spot i think for gaming and productivity (it was all cooled by water, very quiet and efficient).
Z270 + 2 x 1080ti is obviously top of the line 3d performance but i think the CPU will need to be cooled by air and the 2 x 1080 ti's i'll put under water.
Anything below those specs can obviously ALL be cooled by a 240mm water setup.
I think putting a 6800k with 2 x 1080ti's would have exceeded the 240mm radiators capabilities. A Ryzen chip on the other hand would be a good alternative because its 95watt TDP vs 7700k's 91watt TDP. However.... with regards to Ryzen, i really wanted to jump on that bandwagon. But with the lack of X370 mATX SLI motherboards I cannot justify it now. I want to show Project Orthrus in the highest performance setting possible for 4k entertainment. Ryzen is not going to facilitate that unfortunately :(
LukeD
529
1,337
Sydney, Australia
I do kinda miss my 6800k + 2 x 1080 setup because i don't think 7700k + 2 x 1080ti's will all work under water.
I'm thinking about testing it, but I'm going to have to order some quick connect fittings i think. I'm a little over pulling all the water-cooling stuff apart and draining the bubbles :p
Reactions: Ceros_X
