*edit*
I wound up in financial trouble after being cheated on a tradd and wound up needing to sell both my 6950x + x99e-itx. Half a year later, I'm back in business (x299e-itx) and will be making a sort of quasi Hermes 2.0, with much more surface area and far, far less universal usability!
My objective with this project is simple. Create the highest wattage cpu cooler within the restrictions of my already overtaxed wallet and ITX cases like the S4M, DSE Breathe etc. This, of course, means that I have a height restriction of between 45-50mm.
My first hurdle is sourcing materials. The only place I've been able to find suitable heatpipes is aliexpress, I would love to find a north American or European source for every component in this project. If you know any, give me a shout.
Next up, the plan! I'm going to use a6x6mm heatpipe copper buckle 70x70mm vapor chamber, 6 250mm heatpipes and several 100x200mm 0.5mm copper sheets for fins. To cut the fins my current plan is to cut out many 100 - 120mm by 10-35mm sheets, form them in to blocks and then cut/drill through that. I plan on fully customizing to each motherboard and or chassis, then running the extra long 250mm heatpipe to the vrms, cpu (of course) and the case itself for a small amount of passive coolimg.
Update - all heatpipe components ordered, ETA is 19-36 days, the manufacturer I ordered from is busy so shipping is delayed 3-6 days, shipping will take 16 - 30. I get a mystery gift though
I'll be breaking this project into phases, using the helpful tags as a reference.
- Concept. My x99e-itx is is on it's way, when it arrives I'll set up basic 3d models
- The materials arrive and I begin building the first prototype.
- If successful, I'm open to selling these coolers to anyone interested. Given clearance models and time I'm confident I could build a Hermes for any motherboard
- Possible ramping up to machining the coolers, this will not only save a time and drive down cost, it would also mean less dependency on my availability to make more
