Thanks for spending the time reading all of that! I appreciate every critiques or comments, so don't be afraid to do so!
Thanks, haha! Glad you liked it.Looks good!
And I'm digging the drawing of the soldier in power armor: http://sigmaeleven.deviantart.com/art/Desert-Guy-585189693
Unfortunately my college doesn't seem to offer it as an option, but I'll look at it in the future.Nice presentation boards! I think you will make a very good product designer, have you considered it as a subject?
Got it. It was just something I did in my spare time. Typos would be fixed in the final version, surely.I like it, but there were a few typos in the couple of panels I zoomed in on. I know Photoshop doesn't spell check, but if you want to turn it into a portfolio I'd paste your copy into Word and then PS to check it out.
Also, I definitely thought it was an indie case company posting a new prototype case when I opened it. Great work!
I was confused looking at the black case above VS the white render.
Then I realized it's your old Node 304 case LOL.
What riser did you wind up going with? I'd op check it fully before you shift your designs around. If it doesn't work out you can get a good quality riser from LiHeat for $40 shipped.
Nice! Did everything fit together correctly?
Other parts are still to arrive but here's a small update:
That part on the top row, second from the left.. Just how thin is that PSU frame?
Look forward to see you putting the components
small update
