Giveaway - LINKUP Ultra PCIE4.0 Riser Cable (The True Gen4 Designed for Gen4))
Hi SFF members!
After extensive testing and development, we want to invite only registered SFF members to participate in the LINKUP PCIE4.0 Riser Giveaway.
By participating, you will have the chance to get a free LINKUP PCIE4.0 Riser Cable (+ free shipping).
We have limited stock dedicated to the giveaway, so participation will be on a first come, first serve basis and dependent on your system setup. Please see the attached file for the quantities allotted for different cases and configurations.
If you're interested, please apply by submitting the following form. If accepted, we will send you an enrollment package with instructions on moving forward. We look forward to hearing from you!
*Please note that this giveaway is not affiliated with SFF.Network or Minute Media in any way. It is solely a LINKUP endeavour.
Application form:
  • Quantities Alloted.pdf
biopunk
248
359
Now that RX 6000 cards are available (kinda), when can we expect some information regarding Gen4 riser's compatibility with them?
Windeh
We've tested two versions work for SM580
1. Straight Version 25cm and 30cm. You will have to remove the holding bracket on the SM580.
2. Reversed Socket version 25cm and 30cm. You will have to remove the holding bracket on the SM580
Both versions work perfectly for nVidia RTX3080, but not AMD RX5000 series.
Here is the photo using Reversed Socket version 25cm:
Would the riser cable not interfere with bottom 140mm fan?
