October 2020 Update:
November 2018 Update:
Main concept
To maximize air passage, we apply lamella design. This design provides up to 50% more air pass area, than regular holes, and works from bottom to top without "air pockets".
Specification
- Now PRIME supports Flex-ATX as well as SFX (SFX-L) PSUs.
- Added support for GPUs up to 250mm (With Flex-ATX PSU).
- Added support for additional 2 x 3.5" HDDs instead of GPU (With Flex-ATX PSU).
- Front USB panel was removed for better appearance and Flex-ATX PSU support.
- New riser — ADT-Link 175mm.
- We finished production and starts assembly.
- We accept pre-orders on December 2018 on our new web.
- During last year, we made some modifications for easily assembly and better appearance.
We redesigned case mainframe. Now top aluminum part is removable for easily assembling
AC Socket was moved deeper inward the case for better appearance
Laser Marking was added
More precisely milling for Power Button (tolerance 0.05mm)
Grade A aluminum surface finishing and glossy chamfer with diamond tooling (not easily take a good photo of it...)
304SS polished steel feet with black matt silicone
All the parts of the case is custom designed, except AC cord extender, USB3.0 cable and PCI-e riser
End of the Update
End of the Update
- Emphasis on appearance and grade A surface finishing
- Materials: Full aluminum body
- Production technologies: Aluminum extrusion and high precision CNC milling
- No banding, no welding, no punching, no ferrum, no painting, no plastic
- Designed specially for Mini-ITX components
- Perfect cooling
- Small size
Specification
- Overall dimensions: 280 x 140 x 200mm
- Net weight: 2.3kg
- Material: Aluminum 6063
- Storage: 2 x 2.5"
- Cooling: CPU coolers with height up to 50mm
- Power Supply: SFX, SFX-L
- USB connectors: 1 External USB 3.0 on front panel
- Indicators: White power LED, green HDD LED on front panel
- Mainboards support: Mini-ITX
- PCI-E 16x cards support: 2 slots. Up to 180 x 131mm
