As I need a working AND portable system ASAP, I decided to postpone further trials - and continuous fails - with the 280 AIO mod in the A4-H2O, and just build a "regular" system with a 240 AIO.
A bit of a back story:
Yesterday night, I tested whether or not the Meshi would fit comfortable in the backpack I aquired, and well, the answer is: noish. In German, there is this fancy word called "Jein" / "Jain" (its not a part of the official vocabulary, but people use it nonetheless). It means: Yes and no - combined.
Yes, it somehow fits, but NO, you cannot put anything else into the backpack; maybe a mouse, but not even a very flat keyboard like the Sharkoon PureWriter would fit without breaking it.
But the A4-H2O as well as the S400 and the S300 fit perfectly, with enough space to spare for keyboard, mouse, and maybe a smaller portable monitor.
So, FOR NOW, this build log is going to focus on a merely "normal" build in the A4-H2O.
Later on, MAYBE, JUST MAYBE, it might change into a less normal AIO build in the S400 V2. But depending on my mood, it could even turn into a very un-normal, but "classic" air cooled build. Also see my ponderings at the S400 Liquid Cooling Mod thread.
So, the usual specs info dump:
Case: Dan Case A4-H2O w/ black panels
CPU: Ryzen 9 7950X
MB: Asrock B650E PG-ITX
RAM: 64 GB DDR5 5200 (main build) / 32 GB DDR5 6000 CL30 (test build) - both Corsair Vengeance
Storage: 2x 2 TB (FireCuda 530 + SK Hynix P41)
AIO: Thermalright Frozen Edge 240 + 2x Arctic P12 Max
PSU: Corsair SF750
GPU: Inno3D RTX 4070 Twin X2 OC White Stealth with "hidden" power connector
Riser: PCIe 4 supplied with the case / with the "server-focused" PCIe riser cable as a fallback option
Case fans: 2x 120 mm slim (bottom), probably Scythe Flex 120 Slim, potentially detachable for secure transport
Case feet: 3 cm rectangular furniture feet (link is mentioned somewhere in the 280 thread)
Yet to aquire:
- AM5 contact frame - mostly for avoiding smearing the thermal paste everywhere
- RGB strip for the bottom, sth. akin to the Phanteks DRGB strip, but without any proprietary BS (suggestions, anyone?)
cu, w0lf.
CPU: Ryzen 9 7950X
PSU: Corsair SF750
Yet to aquire:
cu, w0lf.
