Power Supply Meanwell NMS-240-12 Questions
cmyk78
384
432
I was looking for a small 12V AC-DC unit and I found this interesting Meanwell unit on Mouser which is very slim with dimensions of 119*38*18mm.
However it appears to be a part of some larger configurable power supply unit and I haven't been able to find out if it is usable as a standalone power supply or if it would need additional filtering from something like the ONE2 Distro 400.
With a high power density, great form factor, and relatively low price if this could be used I think it would be great for SFF systems.
Does anyone know if this will work?
Sicaris
112
68
Looks like this is an output module for a 1U power supply so it needs to be combined with a larger unit. Also looking at the spec sheet the ripple from the 12v unit is 150 mV which is higher than is recommended for computer components.
