NVDIA GPU Compatibility List
Hellow
151
27
Looks like the Gigabyte SUPER GAMING OC serie won't fit L=286.5 W=114.5 H=50.2 mm and same for the AORUS SUPER serie L=290 W=134.31 H=59.9 mm...
davbojic
Also compatible:
GeForce RTX 2080 Ti VENTUS 11G OC
268 x 112 x 50 mm
GeForce-RTX-2080-Ti-VENTUS-11G-OC
dondan
DAN Cases
1,871
7,946
@davbojic This is wrong, only the none OC edition will fit. The none OC edition is only 2 slot while the oc edition is 2.25-2.5 slot. The numbers for the none oc eition is wrong on MSI website.
Boganator
must be bloody close to the side panel. any turbulence effects when the fans ramp up?
I can also confirm that it fits and I have not experienced any turbulence. I've only noticed what I would call normal fan noise, no vibrating or whistling.
Something to note though for other people considering the MSI GTX 1660 ti Gaming X and a Dan Case A4, is that it just BARELY fits. I had to zip tie the card to the case spine and put little spacers (felt pads with a sticky side) between the shroud and the side panel. Without the spacers the side panel would touch the fan and prevent it from spinning. That being said, the panel is closed on the case, the fan spins, and temps and noise levels are great. If you are willing to do some super low level mods, the card works great with the Dan Case A4. Hopefully other people find this useful.
BennyBait
33
@dondan happen to know if an EVGA FTW3 1080ti will fit with the Asetek 645LT in the v3? Have gotten a ton of conflicting answers when asking people, most people aren't sure about the radiator pipes hitting the pcb.
For anyone wanting info on this, here's a good video with information about the lengths of cards with the 645lt installed.
integer
34
Here is the RTX 2080 & RTX 2080 Ti compatibility list:
RTX 2080 Ti Cards:
NVIDIA GeForce RTX 2080 Ti Founders Edition = compatible
ASUS Dual GeForce RTX 2080 Ti Advanced = incompatible (3 Slot)
ASUS Dual GeForce RTX 2080 Ti OC = incompatible (2.5 Slot)
ASUS Turbo GeForce RTX 2080 Ti = compatible
EVGA GeForce RTX 2080 Ti XC Gaming = compatible
EVGA GeForce RTX 2080 Ti XC Ultra Gaming = incompatible (3 Slot)
Gainward GeForce RTX 2080 Ti Phoenix GS = incompatible (3 Slot)
Gainward GeForce RTX 2080 Ti Phoenix = incompatible (3 Slot)
Gigabyte GeForce RTX 2080 Ti Gaming OC 11G = incompatible (2.5 Slot)
Gigabyte GeForce RTX 2080 Ti Windforce OC 11G = compatible
INNO3D GeForce RTX 2080 Ti Gaming OC X3 = compatible
INNO3D GeForce RTX 2080 Ti X2 OC = compatible
KFA² GeForce RTX 2080 Ti OC = compatible
MSI GeForce RTX 2080 Ti Duke 11G OC = incompatible (2.5 Slot)
MSI GeForce RTX 2080 Ti Gaming X Trio = incompatible (3 Slot)
Palit GeForce RTX 2080 Ti GamingPro OC = incompatible (3 Slot)
Palit GeForce RTX 2080 Ti GamingPro = incompatible (3 Slot)
PNY GeForce RTX 2080 Ti Blower Design = compatible
PNY GeForce RTX 2080 Ti XLR8 Gaming Overclocked = compatible
Zotac Gaming GeForce RTX 2080 Ti AMP Edition = incompatible (3 Slot)
Zotac Gaming GeForce RTX 2080 Ti Triple Fan = incompatible (3 Slot)
RTX 2080 Cards:
ASUS Dual GeForce RTX 2080 OC = incompatible (3 Slot)
ASUS ROG Strix GeForce RTX 2080 OC = incompatible (2 Slot)
EVGA GeForce RTX 2080 XC Gaming = compatible
EVGA GeForce RTX 2080 XC Ultra Gaming = incompatible (3 Slot)
Gainward GeForce RTX 2080 Phoenix GS = compatible
Gainward GeForce RTX 2080 Phoenix = compatible
Gigabyte GeForce RTX 2080 Gaming OC 8G = incompatible (2.5 Slot)
Gigabyte GeForce RTX 2080 Windforce OC 8G = compatible
INNO3D GeForce RTX 2080 Gaming OC X3 = compatible
INNO3D GeForce RTX 2080 Jet = compatible
INNO3D GeForce RTX 2080 X2 OC = compatible
KFA² GeForce RTX 2080 OC = compatible
MSI GeForce RTX 2080 Duke 8G OC = incompatible (2.5 Slot)
MSI GeForce RTX 2080 Gaming X Trio = incompatible (3 Slot)
MSI GeForce RTX 2080 Sea Hawk X = unknow
MSI GeForce RTX 2080 Ventus 8G OC = unknow
Palit GeForce RTX 2080 GamingPro OC = compatible
Palit GeForce RTX 2080 GamingPro = compatible
PNY GeForce RTX 2080 Blower Design = compatible
PNY GeForce RTX 2080 XLR8 Gaming OC Triple Fan = compatible
PNY GeForce RTX 2080 XLR8 Gaming OC Twin Fan = compatible
Zotac Gaming GeForce RTX 2080 AMP Edition = incompatible (3 Slot)
Zotac Gaming GeForce RTX 2080 Blower = compatible
Is this list still accurate for the 2080ti's. Dan said somewhere that OC 2080ti's not compatible, but some of those are listed in green above.
rahid905
ASUS GeForce RTX 2060 Dual Overclocked Dual-Fan 6GB GDDR6 PCIe 3.0 Graphics Card
Is this compatible in DAN A4v4 case
