Dan A4 Compatible Radeon RX 5700 cards
dondan
DAN Cases
1,871
7,946
These cards should fit:
  • AMD Radeon RX 5700 (XT) Ref.
  • ASRock Radeon RX 5700 (XT) Challenger
  • PowerColor Red Dragon RX 5700 (XT)
  • Sapphire Pulse Radeon RX 5700 (XT)
I don't think the PowerColor is too high.
mymlan
Has anyone confirmed the Sapphire Pulse as fitting? The measurements make it look like it may be a millimeter or two too wide.
Edit: Sapphire claims the Pulse is 46.5mm wide (including backplate), putting it 1.5mm over the limit unless there's a trick to squeezing some extra wiggle room.
laughingman
Erikdayo
According to the specs of the case and the specs of the GPU it will not fit. What more do you want to know? If you don't trust the specs feel free to buy one and let us know. You can return it if it doesn't fit?
laughingman
Sadly, we can't return the item if it's not compatible.
I just want some reassurance to what @dondan said that the Sapphire Pulse RX 5700 XT will fit in the Dan A4 as it contradicts the case specification which is only limited to 2 slot (< 45mm?)
Reactions: mobie1211
mobie1211
I find someone using 50mm 2080 in A4
laughingman
*Update
The Sapphire Pulse Radeon RX 5700 XT does not fit in the Dan A4 V4. Sad.
Either get 3D printed side extender or go with PowerColor Red Dragon RX 5700 XT
Reactions: Titeywitey
EatDahPewPew
I have a Red Dragon 5700 XT. On paper it should be fine but I am worried to be the first tester. Has anyone here tried it out yet?
Currently using a Nano define S and I would like to go smaller.
Sparky
Is there plenty of clearance to plug in the power cables? Or is it kind of a tight fit?
I have a Red Dragon 5700 in my A4 and it fits fine. I think plugging in the power cables first before you set the card in is the way to go. I did not find it terribly tight at all, but it was definitely tighter than my old 970 FTW+. If you look close on my second pic it does seem to push the card down a bit.
Here was my build.
