NVDIA GPU Compatibility List
CianXIII
I made an NVDIA GPU compatibility list for the Dan A4 based on specs on the website. I was able to get most specs on each manufacturers websites but some may be inaccurate or missing. Please let me know and I will correct it. Feel free to use this and make a better one for us all as I'm not that familiar with spreadsheet software. This is for people who are looking for a GPU for their Dan case rather than having to research thoroughly in what fits such as myself. All I read from my research was variants of “maybe”, “tight fit”, “check the specs if it matches”, “etc”, manually checking google for images of builds to see if it would fit. The lazy person I am decided to make this in a short amount of time instead of going to forums and finding mixed answers, comparing specs every time, and googling images of builds. So here I am with it and decided to share it. For all you lazy folks out there here you go. Regarding EVGA they don't have the width in their website so I was unable to place it there but all of their GPUs seem to fit in the case perfectly. Zotac should all be the same throughout so I never bothered looking and putting it down. Please check before you buy!
NVDIA Dan A4 GPU Compatibility List Image
dondan
DAN Cases
1,871
7,946
Here is the RTX 2080 & RTX 2080 Ti compatibility list:
RTX 2080 Ti Cards:
NVIDIA GeForce RTX 2080 Ti Founders Edition = compatible
ASUS Dual GeForce RTX 2080 Ti Advanced = incompatible (3 Slot)
ASUS Dual GeForce RTX 2080 Ti OC = incompatible (2.5 Slot)
ASUS Turbo GeForce RTX 2080 Ti = compatible
EVGA GeForce RTX 2080 Ti XC Gaming = compatible
EVGA GeForce RTX 2080 Ti XC Ultra Gaming = incompatible (3 Slot)
Gainward GeForce RTX 2080 Ti Phoenix GS = incompatible (3 Slot)
Gainward GeForce RTX 2080 Ti Phoenix = incompatible (3 Slot)
Gigabyte GeForce RTX 2080 Ti Gaming OC 11G = incompatible (2.5 Slot)
Gigabyte GeForce RTX 2080 Ti Windforce OC 11G = compatible
INNO3D GeForce RTX 2080 Ti Gaming OC X3 = compatible
INNO3D GeForce RTX 2080 Ti X2 OC = compatible
KFA² GeForce RTX 2080 Ti OC = compatible
MSI GeForce RTX 2080 Ti Duke 11G OC = incompatible (2.5 Slot)
MSI GeForce RTX 2080 Ti Gaming X Trio = incompatible (3 Slot)
Palit GeForce RTX 2080 Ti GamingPro OC = incompatible (3 Slot)
Palit GeForce RTX 2080 Ti GamingPro = incompatible (3 Slot)
PNY GeForce RTX 2080 Ti Blower Design = compatible
PNY GeForce RTX 2080 Ti XLR8 Gaming Overclocked = compatible
Zotac Gaming GeForce RTX 2080 Ti AMP Edition = incompatible (3 Slot)
Zotac Gaming GeForce RTX 2080 Ti Triple Fan = incompatible (3 Slot)
RTX 2080 Cards:
ASUS Dual GeForce RTX 2080 OC = incompatible (3 Slot)
ASUS ROG Strix GeForce RTX 2080 OC = incompatible (2 Slot)
EVGA GeForce RTX 2080 XC Gaming = compatible
EVGA GeForce RTX 2080 XC Ultra Gaming = incompatible (3 Slot)
Gainward GeForce RTX 2080 Phoenix GS = compatible
Gainward GeForce RTX 2080 Phoenix = compatible
Gigabyte GeForce RTX 2080 Gaming OC 8G = incompatible (2.5 Slot)
Gigabyte GeForce RTX 2080 Windforce OC 8G = compatible
INNO3D GeForce RTX 2080 Gaming OC X3 = compatible
INNO3D GeForce RTX 2080 Jet = compatible
INNO3D GeForce RTX 2080 X2 OC = compatible
KFA² GeForce RTX 2080 OC = compatible
MSI GeForce RTX 2080 Duke 8G OC = incompatible (2.5 Slot)
MSI GeForce RTX 2080 Gaming X Trio = incompatible (3 Slot)
MSI GeForce RTX 2080 Sea Hawk X = unknow
MSI GeForce RTX 2080 Ventus 8G OC = unknow
Palit GeForce RTX 2080 GamingPro OC = compatible
Palit GeForce RTX 2080 GamingPro = compatible
PNY GeForce RTX 2080 Blower Design = compatible
PNY GeForce RTX 2080 XLR8 Gaming OC Triple Fan = compatible
PNY GeForce RTX 2080 XLR8 Gaming OC Twin Fan = compatible
Zotac Gaming GeForce RTX 2080 AMP Edition = incompatible (3 Slot)
Zotac Gaming GeForce RTX 2080 Blower = compatible
Reactions: Protools
elephantnut
How strict is the 45mm w/ backplate measurement? The MSI GTX 1660 TI Gaming X is at 46mm according to MSI's specs. Awkward measuring tape angle here.
boogahead
Mar 3, 2019
My Galax gtx1080 ex oc just hits 144mm in height, which is just the same as the gpu height limitation for the case. Will it still fit?
dondan
DAN Cases
1,871
7,946
@nymphrine: I never test all cards I go to every specification page on the manufacturer side and validate it.
Here is a list of cards that should fit: https://geizhals.de/?cat=gra16_512&...plz=&dist=&mail=&sort=p&bl1_id=30#productlist
I think this one: MSI GeForce RTX 2060 Ventus XS 6G OC is a good pick. Or this one ASUS Phoenix GeForce RTX 2060 if you plan to use a 120mm AIO
@boogahead
If you mean this one: http://www.galax.com/en/graphics-card/10-series/galax-geforcer-gtx-1080-exoc.html it should fit.
XM1014
@dondan happen to know if an EVGA FTW3 1080ti will fit with the Asetek 645LT in the v3? Have gotten a ton of conflicting answers when asking people, most people aren't sure about the radiator pipes hitting the pcb.
Franziskan
May 31, 2019
Hello, I've a Zotac AMP extreme card and i'm seeing that doesn't fit on, so there is something compatible in order to replace the standard heatsink or probably and even better an AiO liquid cooler...
Thanks. Francesco.
Killaa_Chris
Hi, first time posting... I know the length and height are ok but can anyone confirm if the ROG STRIX RTX 2080 Ti can fit in the case with the side panel removed?
