Hi
Is anyone interested in being able to get a Noctus fan that's a straight swap with the correct pin header. For the Enhance ENP-7660B / Silverstone fx600?
Let me know if any interest and any colour prefs (ie Noctua baby poo brown or black)
cheers
Of course, can ship anywhere. Shipping to US would be £8.10 + £0.35 for each additional fan in a single shipment. ie 1pcs £8.10, 2pcs £8.45. 3pcs £8.80 etc.Would you be able to ship to US?
Hi,I don't see this fan on your site yet.... am I missing it?
I have an MF-600f, a modular PSU from Aliexpress, and I'd like to swap the 40mm fan for the Noctua NF-A4x20.
Now your one from Aliexpress, this I believe is a clone (ripped off design) with a different component set and not produced by Enhance. The fan controller may work at different voltage levels and this may not be suitable for that power supply.
The only way to asses it is to get a multimeter on the fan header and see what voltage is being pushed out with PS ON taken active low and no load. Also helpful would be to know the fan model they have used to get the fan datasheet. The stock fan in genuine product is an ADDA that's custom for Enhance with a lower than standard startup voltage. Nominally for 12v fans this is 4.5V, but the ADDA will run from around 2.4V.
Better still is if you can get the producer to provide the psu fan voltage V load map ideally at 20C and also 40C ambients.
Cheers,here is the original fan model of the TaoBao PSU:
Although I haven't checked with a multimeter, the fan (voltage) curve of that PSU appears to be a bit more "aggressive" compared to the original ENHANCE.
I've modded mine with a 12V NOCTUA and can confirm it works fine so far (tested between ca. 0~450W load). Hope this helps.
I do have a 12V 40mm Noctua on hand, that I think is unmolested. We just looked at it to see what startup voltage it could run with and worked out it was totally unsuitable for enhance 7660B. Will check on Thursday and if suitable could setup for a suitable straight swapThanks for the reply. @REVOCCASES did a great teardown on the MF-700f from the same company. A Noctua swap seemed to work and did well in reducing noise. The original fan used is:
Edit: @REVOCCASES you are amazing. I can't thank you enough for all the work you do... even snipping my post as I was working on it.
Do have a 12V version on hand, drop me a message if you are interested in buying it with 2.0mm pitch pin header fitting so it can be easily swapped in with a reliable connection.Thanks for the reply. @REVOCCASES did a great teardown on the MF-700f from the same company. A Noctua swap seemed to work and did well in reducing noise. The original fan used is:
Give your eyes a little rub, nope you're not dreaming.Wait, what? Does a black version of NF-A4x20 even exist?
