Noctua 40mm NF-A4x20 FLX or PWM? (for flex atx psu)
Tester
I have the Flex ATX Enhance ENP-7660B coming. As I understand it I can replace the stock fan in one of two ways.
1. Use the 3 pin FLX fan and connect it to the original psu internal header.
2. Use the 4 pin PWM fan, connect it to the motherboard and set a fan curve through software.
Can someone experienced with this give me an idea which would be the better approach? Thanks.
der_brennesel
Internal header is always the better approach to PSU Fan modding as the Motherboard has no idea about PSU thermals, but the PSU does. Some PSUs don't have a decent fan control though so improvement might be minimal.
I'd give the internal approach a try and if it doesn't work switch it to the motherboard.
You can use 4-Pin Fan for both internal and external connection so i'd go for the PWM version. They both come with the same adapters (2-pin internal) and connectors.
Reactions: Bennu
paulesko
414
322
There are motherboards that can take an external temp sensor (asus x570-I rog gaming for example) and you can draw your own curve based on that sensor (that you can place inside the psu) also you can use a fan controller like a aquacomputer quadro, that can take several temp imputs and control up to four different fans each of them with a different curve related to a different temp.
