S4 MINI Classic (S4M-C)
DocH
G4G
Apr 2, 2017
314
306
California
Does a larger fan over the whole board do well or is it just better to use a 92mm fan on the heatsink?
you can give it a try but it depends on the cooler underneath really. I found smaller fans have better pressure right on the cooler so it worked better then a larger fan above. It also allow heat to escape on the sides but again everyone may have different results.
josh said a fan behind the gpu helps a lot. I found smaller fans on the gpu heatsink helped a lot as well. i never tried with the standard cooler on my 1080. make sure you run it with the panel on as that makes a difference
gunpalcyril
294
319
@Illoominatty I've tried that setup with that exact same fan in the s4, using the heatsink of a l9i cooler. It performs better heatwise, but there is a noticeable noise increase. Though, its not an annoying high pitched noise, but more of a noticeable deep "woosh" noise.
That being said, I eventually moved back to using the stock 92mm fan of the l9i, its much quieter even under load in comparison.
Reldey
387
405
Atlanta, GA
@Reldey That external psu though, isn't it a hassle? especially since the cords are so thin.
I've been looking to buy a gechic portable monitor for quite some time. Hows the gaming performance? Any noticeable lag, ghosting, stutters?
It is, @royalba94 is working on a mod for it currently, to clean up the cables and better contain the fans and their cables.
In the meantime, I gave @guryhwa a shout and installed one of his units. It is working really well, although the brick is quite large. That is just how it has to be though given it's passive cooling.
The gaming performance on the monitor is fine. It pales to my Dell GSync, but the brightness is OK and the contrast is decent given it is an IPS screen. If you sat me in front of another 1080p IPS monitor, I doubt I could tell the difference, but I haven't done much FPS gaming on it, mostly just RPG/MMO stuff.
Also, I tried a little mod suggested earlier in the thread with my Zotac GTX 1080 Mini. Went to Microcenter today and picked up a small 5cm x 5 cm 8 0.5 thermal pad to act as a thermal transfer point inbetween my GPU heatsink and the aluminum bezel. Pictures below:
As far as results, I have seen a drop of about 4-5 degrees celcius under load. The bezel now gets VERY hot, not sure how much of an issue that is, I assume not as long as I don't try to pick it up by the bezel while it is under full load, as it cools down quite quickly.
Jordy
43
47
28
The Netherlands
Just wanted to share a pic of my S4 Mini out in the wild...
Also just to note, using the GeChic 15.6 inch portable screen, and it fits perfectly above the S4 Mini. I am sure I'm not the first one to do this, just thought it was funny how the little feet on the display JUST sit at the edge of the wrap-around bezel and side panels.
That poor laptop in the front, i have the same idea to bring a s4 mini with a portable screen to class. People with overpriced MSi laptops are gonna be jealous lol. Nice
Biowarejak
Maker of Awesome | User 1615
1,744
2,262
Texas
Can someone please measure the distance between the side panels on the interior? I'm getting 2 3/8" from the model and I just want to be sure :)
Reactions: AleksandarK
SpringerTheNerd
195
209
32
Seattle WA
I love that this actually made a difference haha. Any reason you didn't just go with the "3D bezel"?
QuantumBraced
507
358
That poor laptop on the front, i have the same idea to bring a s4 mini with a portable screen to class. People with overpriced MSi laptops are gonna be jealous lol. Nice
You bring this setup into your university library and you are going to stand out as a total badass haha. They'll probably hate you if you use a mechanical keyboard there though.
The product we REALLY need is a cheap and practical 15" laptop shell - that is, just a monitor, keyboard, and trackpad (and maybe external battery) in a laptop body that you can connect to your mini PC to make it portable. Still, nowhere near as practical as an ultrabook if you need to do light work, but if you need to travel with serious power, that setup would destroy any gaming laptop as far as power/cost/customization and you can also connect your phone/tablet to a laptop shell like this for web browsing and such. So it's quite practical. I know it's been done with the Nexdock and Superbook, but I wish it would seriously take off and we'd see some good and available units from serious companies out there, and proper Android support. I can see people connecting NUCs to it too. It would make the S4 Mini more portable.
I feel like right now we're in a state where sub-5L cases have the potential to be portable, but because you have to carry around a monitor/keyboard/mouse, they're not really portable. And if it's going to sit on your desk, you may as well have something a little larger that can cool better and have internal power, hence why the M1 is so popular - still tiny, but no compromises. But if portability truly became feasible, then all of a sudden having something you can easily toss in your backpack becomes very appealing, and the external brick starts to make more sense as it's more portability-friendly. With a laptop shell and the S4 mini, it would be like having an ultrabook + eGPU, except much cheaper and much more powerful.
SpringerTheNerd
195
209
32
Seattle WA
Reldey
387
405
Atlanta, GA
Here is something.... https://pi-top.com/
Illoominatty
111
162
Anyone putting K version cpus in their S4 minis? I'm going to get intels 8th gen CPU just don't know if K or not. I know the perks and con's just curious on who actually run the K versions in their rig if they like it or not. Temps and results.
br3nd0
307
297
Toowoomba, Queensland, Australia
@CubanLegend stuck a delidded 7700k in his S4 "Ant-Man" rig, which has a 91W TDP. The 8700k has a 95W TDP, but the extra 2 cores it has over the 7700k could chew up some extra power when loaded. Check out his comprehensive thread for a full run-down :thumb:
Reldey
387
405
Atlanta, GA
I stuck a 7600k in mine since I was running a z270i and overclocked ram anyway. Haven't overclocked it or anything, and temps are stable. I still don't really see the need for the i7 over the i5.
