Wohhh how did you do that senpai. Wow I never thought about the mirror and black that is sexy. I might have to do this.Go get a skin made or polish it! It only takes about 20 hours of polishing!
I applied the wrinkle paint. Already the slight wrinkles are coming through. I think this is one is gonna work well and look great. I'll post updates.
SO SHINY O_OGo get a skin made or polish it! It only takes about 20 hours of polishing!
1. strip paint
2. sand with 400 grit until smooth
3. wet sand with 800 grit
4. wet sand with 1000, 1500, 2000
5. bust out the metal polish and spend the next 10 hours polishing it.
It's not fun, but boy howdy does it look nice!
Like new againAnd the side panels are done# Im gonna be uploading a video on the process of how I did this and how strong this paint is.
What wrincle did you sprincleLike new again
Like new again
Lol! VHTWhat wrincle did you sprincle?
I mean the brand?
Incredible resultsLike new again
Image isn't showing for me.Just wanted to share a pic of my S4 Mini out in the wild...
Also just to note, using the GeChic 15.6 inch portable screen, and it fits perfectly above the S4 Mini. I am sure I'm not the first one to do this, just thought it was funny how the little feet on the display JUST sit at the edge of the wrap-around bezel and side panels.
